Sickle Bar Will John Deere 350 9' sickle mower fit and operate on a Kubota L3400
   / Will John Deere 350 9' sickle mower fit and operate on a Kubota L3400 #1
dweitzel
SE, IN
Cub Cadet 7360SS
Will John Deere JD 350 9' sickle mower fit and operate on a Kubota L3400's 3-point lift arms and clear the top link assembly? I have a Cub Cadet 7360ss which is pretty comparable in size to the above Kubota. Most people are familar with the Kubota and not the Cub series, so that's why I asked.
I'm a little confused as some say yes it will, but others are saying that it will not fit between the lift arms? Can it be made to work on this tractor? Is the inside dimension on the rear wheels sufficient to run this mower? I have the AG tires on the tractor if that makes a difference. I think the turf tires may be a little wider if that helps.
I have one lined up to purchase but the owner does not know if it will fit and it's a bit of a drive to go test it out.
Any help would be appreciated.
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
Entyre Chip Spreader (A51573)
Entyre Chip...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
John Deere S780 Combine (A53342)
John Deere S780...
