will it take off?
/ will it take off? #141
NewToy said:
...Take the little childs toy with 5 or 6 ball bearings suspended with the strings. Pull one ball back and let her go, that energy causes a reaction making the other ball at the opposite end move. ...
The balls will eventually stop, not on their own, but because of air resistance, gravity, etc... they won't just keep going forever.
As far as the rocket in a dark place, well, that was not very nice! :D ... but there is a video of someone doing that on you tube (and a link to it will not be posted here on TBN).
/ will it take off? #142
Tom, Let me ask something about the conveyor here. Are you saying that if a plane is sitting on a conveyor and the conveyor starts that the plane, in this case under no power yet or thrust will stand still in relation to the ground while the wheels turn under it because there is no friction? Where on earth is there no friction. If you placed a model car on a tread mill and started it moving won't the car follow the belt rather than standing still and fall off.
/ will it take off? #143
shaley said:
I'm saying these fish have wings and the beat them pretty hard and fast. You can hear the flutter when the come out of the water. I'm just as amazed at the Tuna for learning how to nail them. Look at the size of the peck wings.
Man, that is some detail. Nice picture. :)
Do you think he wished the tuna was on a treadmill?
/ will it take off? #144
The Tuna WAS on a treadmill, thats the only way he could get airborn.
/ will it take off? #145
MossRoad said:
No such treamill exists. If the treadmill could match the wheel spin exactly, it would turn at the exact same moment the wheel turned, keeping it in the exact same place in relation to a point on the ground , no matter how much thrust you applied.
If the plane is standing still it has to overcome the friction with the ground to first get moving. Once it is moving, it can then pick up speed. It will never break this friction if the wheel makes no forward progress due to the magic treadmill. No initial forward motion means no forward motion ever due to the magic treadmill. Now, if the treadmil had a short delay in its initial reaction time, I would say, sure, it will constantly be trying to catch up and the plane will always be ahead and eventually take off. But we are assuming a magic treadmill that would never let the plane leave its initial spot to start with. Nope. No fly today. :cool:
Let's take the propeller off the plane and replace it with a winch. Take the winch cable and attach it to a fixed object in front of the treadmill. Activate the winch and treadmill at the exact same time same speed etc, the plane will be pulled forward with the wheels spinning twice as fast as they would be sans treadmill. Same concept with the propeller reinstalled. The plane will move forward when thrust is applied you just can't see a cable pulling the plane the thrust is moving the plane forward in relation to the ground. The plane and treadmill just double the wheel speed over a plain old runway. The surrounding air is NOT attached to the treadmill and the thrust applied to the plane has to move it, there is no other way for it to work. The energy applied to the plane as thrust has to create that equal and opposite reaction thing. The forward motion is not being applied to the landing gear but to the air as thrust. therefore, up, up and away.
John
/ will it take off? #146
755inNY said:
Assuming the plane is on wheels and the wheels can spin freely at the speed of the movable runway, the plane will take off when it reaches the airspeed required for take-off. The airflow from the prop or jet or the breeze from the moving runway will never provide enough lift for take-off.
Look at it this way. There is a 1 mile long conveyor 2 feet wide 4 feet off the ground (for convenience). On the conveyor is a box. The box has wheels at each corner. A pole runs through the box and extends 3 feet to either side of the conveyor. You are on one side of the conveyor and schmism is on the other side. You both start walking at the same speed each pushing on the pole running through the box. The box will move along the conveyor. The conveyor is controlled to move in the opposite direction of the box at the same speed as the box is being pushed by you and schmism. The faster you and schmism go the faster the conveyor goes. As you pick up the speed and run pushing the box at 10 mph, the conveyor increases its speed to 10 miles per hour in the opposite direction. Will you get to the end of the 1 mile conveyor (assuming you both can run a mile at 10 mph)? Of course you will. And, in reaching the the end of the conveyor, you would have moved though the air mass surrounding you at a speed of 10 mph.The force moving the box is independent of the wheels contacting the conveyor. The wheels will be spinning at a rate equal to 20 mph during your run.
A similar condition exists with the plane. The plane is being moved by the propeller, or jet engine if you prefer, independent of the wheels contacting the movable runway. The plane will move through the air mass while the movable runway moves at the same speed in the opposite direction. At the proper airspeed (plane moving through the air mass) the plane will take off and the wheels will be very thankful because they can finally stop spinning so **** fast!
Jeff
Nice to see someone get it right, and with a good description to boot! the key here is in the original description of the problem:
[q]a plane is standing on a movable runway( something like a conveyor).as the plane moves the conveyor moves but in the opposite direction.the conveyor has a system that tracks the speed of the plane and matches it exactly in the opposite direction.[/q]
If the plane is moving forward at 50 MPH, the conveyor belt matches this and spins 50 MPH in the opposite direction. This has no effect on the forward speed of the plane (ok, maybe SLIGHT losses due to friction in wheel bearings). The plane will lift of with it's wheels spinning at 100 MPH (assuming 50 MPH is enough to get airborne)
While I'm not ruling out the possibility, I've never seen a plane where the engine (whether prop or jet) provides enough airflow over the wings for the aircraft to take flight without first rolling forward (excluding VTOL, but then it's actually more of helicopter type mode, and the conveyor belt is irrelevant). Even the military jets don't take off without some forward motion. With enough power, the length of this motion may be rather short, since it can get up to flying airspeed rather quickly.
EDIT: oops... I have seen one instance of an airplane taking off without rolling forward. I saw a guy take off into a 30 knot or so headwind. As 30 knots was enough to fly in that aircraft (at least in ground effect), all he needed was for the guys holding his wing struts to keep him on the ground to let go... he just floated right up. I've seen a similar thing when aircraft float up against their tiedown ropes in a strong windstorm.
John Mc
/ will it take off? #147
MossRoad said:
Put on some roller skates and stand on a treadmill. Hold a CO2 fire extinguiser under your arm and point it backwards. Have someone turn on the treadmill and fire off the fire extinguisher. You will shoot forward no matter what the speed of the treadmill, right? Except that according to the original question, the treadmill will match your wheel speed. In order to go anywhere forward, your wheels would have to turn faster than the surface of the treadmill. Soooo, I am back to the school of thought that this is a tough question.
Except that the original question doesn't say the conveyor will match the wheel speed it says "the conveyor has a system that tracks the speed of the plane and matches it exactly in the opposite direction." Nothing about wheel speed, it's the speed of the plane that matters.
Given this, I'm not sure how the conveyor could ever match the wheel speed, except when every thing is not in motion. Imagine the plane starts moving forward at 1 MPH. The conveyor senses this and matches it with 1 MPH in the opposite direction. But now the wheels are moving at 2 MPH (aircraft moving forward at 1 MPH since it's being pulled by the prop, converyor moving back at 1 MPH = 2 MPH on the wheels). Now, if the converyor is sensing wheel speed, it "senses" 2 MPH and speeds up to that speed. Wheels are going 3 MPH (assuming plane has not accelerated further). The converyor senses this and speeds up again. All it does is keep speeding up if the plane has any forward motion at all. It will never slow or stop the plane unless the wheel bearings tie up.
John Mc
/ will it take off? #148
John
What is the winch in your example attached to? Something that is attached to the same ground that the treadmill is sitting on, that's what. A winch attached to the ground is not the same things as air flowing over that ground.
I believe that the perfect magic treadmill (if it existed) that could exactly counteract the wheel's rotation from the instant it tried to roll would act just like a rope tied to the plane's tail and keep it from moving. The airplane would just be a big fan blowing air behind it, anchored to the treadmill by the friction between the tires and the surface of the treadmill.
To be honest, the entire scenario is not possible, because a treadmill that can exactly counter the wheel's movement does not and cannot exist. It would have to intuitively know when to turn BEFORE the wheel ever turned, otherwise it would be a reaction, not an action.
/ will it take off? #149
John Mc
That explanation I agree with. It is just a matter of how we interpret the scenario. Your exlanation above makes sense to me. My interpretation of the scenario starts with the conveyor countering the wheel rotation as it occurs, not after it occurs.
/ will it take off? #150
Anyone ever read A wrinkle In Time? I had an easier time understanding tessering than this treadmill thing! :p
/ will it take off? #152
I think I see a myth buster show for this thread in the furture
roger
/ will it take off? #153
N80 said:
And if a car is moving at the speed of light and turns its headlights on, do they do anything?
What hits the ground first, the bullet shot from a level gun barrel five feet off the ground or a bullet dropped straight down from five feet at the exact same time the other bullet leaves the barrel.
The headlights will shine normally and the dropped bullet will hit the ground first.
Newton says the bullets hit at the same time but he didnt take into consideration that the bullet is spinning. That keeps it on a flatter trajectory through spin stabilization
/ will it take off? #155
Time to show off my level of ignorance...
If the plane is sitting STILL on said conveyor the weight of the plane is on the wheels, right?
The plane can't take off until said weight is transferred to the wings, right?
Seems to me that transition is made during the process of takeoff as the plane speeds through the air, creating lift over the wings.
Since the plane has all its forward motion nullified by the reverse motion of the conveyor, how, where and when, does the plane garner the forward airspeed to transfer said weight onto the wings & take off?
Who ever created this thread needs to be tarred & feathered!!
:D
/ will it take off? #156
I done a lot of thinking on this yesterday. I'm the first to admit I'm a little slow but that dang plane will fly.
All you non believers, put your imagining hats on now and follow me.
You have said plane and said conveyor but for this demonstration we need one more item. We build a human runway above the plane and next to the tail (the part that sticks up).
You get on the runway, the pilot starts the engine, throttles up and you start pushing the plane forward by it's tail. You're a very strong (Incredible Hulk) person. You push the plane forward faster and faster. You know the plane is moving forward because you are. You go faster and faster. You feel the wind in your face getting stronger (wind speed). Right at the end of 'your' runway you are running at 80 MPH and the plane leaves the ground.
In conclusion I've finally been able to separate the plane's wheels and the conveyor from the real story. As said many times before, in the thread, the plane's wheels and the conveyor are a none issue. I just had to get it straight in my mind.
/ will it take off? #157
Wow...interesting stuff. I am amazed that there is such STRONG conviction on either side of the argument. Every is convinced they are correct - which makes this more interesting. Just to weigh in here:
I think everyone agrees that this plane (assuming a typical plane) must have forward motion to take off - so the question is...can it move.
If the magic conveyor truly matches the speed of the wheels there will be no forward motion of the plane = no flight. I understand what people are saying about the wheels not driving the plane - the prop does - but the wheels still represent the speed of the plane relative to the ground. So if the prop gets the speed to 60mph the conveyor is going to magically make that zero mph by moving in the opposite direction. So no matter what the prop does, it can't move the plane until it can separate the plane from the magic conveyor (which it can't do).
No forward motion = no lift off
/ will it take off? #158
I believe with sophisticated controls and computers monitoring the plane the scenario would be very possible. Let's pool all of our money and commission JPL to build us the perfect treadmill so we can put this to bed. :rolleyes:
The winch is attached to a FIXED point on the ground just in front of the treadmill. When engaged the winch would pull the plane forward regardless what the conveyor is doing. The result would be the wheels on the gear doing 2x the speed that the plane is moving forward. The propeller is spinning in fixed air not attached to the treadmill resulting in the plane moving forward with the wheels doing 2x with the conveyor in the opposite direction. The thrust created by the prop is the same thing as a cable as the prop pulls it's way through the viscous atmosphere the plane has to move forward. It will eventually come to you when you get around your fixation on the conveyor that really has nothing to do with the plane moving forward. The plane will fly!
Pick up a few Stephen Hawking or Michio Kaku books and really read them. They will help you look at things from outside the box. They have some ideas about our existance and surroundings that really get you thinking.
Like you said, the plane will be generating thrust in a rearward direction resulting in an equal and opposite reaction, (Plane goes forward). I don't understand how you think the "friction" in the wheel bearings and tires could negate all the thrust the engine generates. The plane would take a tiny bit longer to achieve liftoff on the treadmill because of the friction you spoke of and the energy burned up with the wheels turning 2x due to the opposing force of the treadmill. You can't see "Thrust" but it will exert the same force on the plane as a cable that you can see.
I am positive the plane will move forward relative to the ground and FLY! It is mandated by the laws of physics, no way around iy.
John
John
/ will it take off? #159
Which makes the winch example NOT comparable to the propeller example. I agree in your scenario, the plane would fly - because it is impossible for the conveyor to make the speed of the plane zero. The winch is moving the cable so the plane HAS to move. Your example basically makes the magic conveyor null and void - it can't eliminate ground speed because the fact that the cable is shortening will mean that it can't match the speed of the planes wheels (would require the laws of physics to change)
In the propeller example, this is not necessarily true. Since the wheels represent the ground speed and since the magic conveyor is countering all ground speed, the plane is not moving. No movement = no flight
/ will it take off? #160
HTWT said:
Ray
The answer is yes. We transmit between ground and planes or between planes at the speed of lignt, not the speed of sound.
And to add to that. The radio the airplane is using is traveling at 0 velocity in relation to the pilot/passengers.
Harry K
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
2014 Caterpillar CB54B Articulated Vibratory Tandem Smooth Drum Roller (A64553)
2014 Caterpillar...
Danuser 3 Point Post Auger (A65640)
Danuser 3 Point...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
2023 Boxer 700HDX Compact Skid Steer (A63109)
2023 Boxer 700HDX...
2012 Great Dane 53' Van Trailer (A66285)
2012 Great Dane...
