will it take off?
   / will it take off? #951
Egon, To fit the conditions, the fast flowing river would have to have easily controlled speed and a max speed fast enough to generate enough hydrodynamic drag to equal the plane's thrust. Perhaps a river on the downstream side of a dam with a huge impoundment that could be released to make a tremendous current.
Nah, I think Eddie's pond and a carefully selected prop with proper engine would be more fitting.
Pat
   / will it take off? #953
If I may jump in,
As the water speed goes up, the contact patch required to support the weight of the plane will get smaller and smaller until a layer of air is finally forced between the hull and the water. At this point the drag will be less than or equal to that of a wheel on a conveyor.
I don't know? THIRD BASE!
   / will it take off? #954
The pond level will definitely go up when you toss the anchor and it is in the air!:D :D :D
   / will it take off? #955
Brad_Blazer said:
If I may jump in,
Brad, In my previous post I allowed as how the float would eventually get up on the step and hydroplane with a resultant loss of hydrodynamic drag that would necessitate an increased water speed to compensate. At this point the plane has effectively zero air speed and thus no lift. Simply passing water under the float with no air speed will not "pack" air under the float in sufficient quantity to eliminate hydrodynamic drag.
The problem as stated is NOT equivalent to having a boat (or float plane) run across the surface of the water where the float or boat would have a relative wind (air speed) as well as a speed through (or across) the water. In the case of the boat or plane going across the surface the relative wind (airspeed would indeed tend to pack air under the float. A properly designed hydroplane hull form is shaped to generate and encourage "foam" under the hull to reduce skin friction.
Now, back to the case at hand where the plane is not moving through the air so no air is being packed under the float(s). Not having specified the type of flotation we must allow for a flying boat where the fuselage is boat-like or there may be a pair of pontoons where the wheels of the landing gear would be in a land plane. The design of the flotation not having been specified, there may in fact be no hydroplane step, just a couple of canoe shaped floats, not conducive to having air directed below them to make friction reducing foam.
As regards "contact patch" area. This assumes that the hull form will induce hydroplaning. If it doesn't and the float(s) remain in the displacement mode drag will increase dramatically when the speed of the water past the flotation devices exceeds approximately 1.3 times the square root of the length of the floats at their water line. The phenomenon of bow-stern wave trap will lower the floats deeper and deeper into the water as the water speed increases until ultimately they are submerged. As a matter of practicality they would be sheared off (if the plane had sufficient thrust) but if we can have a "magic" submerged prop and motor to run it why not magically strong floats and their connection to the plane too.
Anyway, even with hydroplaning since the air speed is essentially zero or a very low value there is no packing of high pressure air under the flotation devices as would be the case in say a racing hydroplane which has both water and air speed.
Thanks for your interest and input but sorry, no pantella.
Pat
   / will it take off? #956
Actually Egon the pond level goes down while the anchor is in th air as the float plane is not displacing a volume of water equal to the weight of the anchor since it is in the air. The pond level comes up a tad when the anchor goes in but not as high as it was when the float supported it by displacing a volume of ware equal to the weight of the anchor.
Come on Egon, think like a Greek (Archimedes.)
Pat
   / will it take off? #957
Well gee, two choices and it's early in the morning, That's what I meant, go down!:D :D :D
   / will it take off? #958
Pat
This is assuming that the anchor is in the air long enough for the plane to recover from the "recoil" from the force of tossing it into the air. (Newton's third law). Initially, the pond will rise a fraction as force is applied between the plane and the anchor forcing the anchor up into the air and the plane deeper into the water.
Of course if you just drop the anchor without throwing it that isn't any fun, and the pond will go down as Pat stated.
   / will it take off? #959
Silly me, I assumed you wouldn't want to startle the fish any more, the ones that weren't run through the magic prop and were already nearly at max nervousness. So you just drop, or lower the anchor. Of course if you toss it out in a parabolic trajectory starting with a finite upward vertical component there will be an oscillation of the level of the pond but the central tendency will be as I previously described and of course the final result will not change assuming the anchor ends up in the water.
I overlooked the case where the anchor is tossed onto the shore and that will result in the water going down even more by the volume of water that the anchor would have displaced had it gone into the water.
A friend of mine at SEE (Santee airport near San Diego) had (and may still have) a 1948 Lake Amphibian ( 4 person flying boat.) If there is a ground swell of enthusiasm to run the full scale experiment I can contact him to see if we passed the hat and got enough response he might be interested in supplying the plane. I have flown with him in various craft and would be pleased to be his relief pilot in helping ferry the plane to the site or taking charge and delivering it myself. With its terrific short landing capability there should be no problem getting it safely down at Eddie's (it has regular landing gear as well as a boat type fuselage for water landings.)
Pat
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
(2) SPRINKLERS & HI-RISE STANDS (A58374)
(2) SPRINKLERS &...
MILWAUKEE & DEWALT SAWZALL (A58374)
MILWAUKEE & DEWALT...
Toro (A56857)
Toro (A56857)
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
