will it take off?
   / will it take off? #871
patrick_g said:
Yes, obviously, if the friction between the skis and conveyor produce less force at the conveyor's speed than the planes thrust then the plane will accelerate.
However IF the conveyor runs fast enough the counter force can equal thrust (or exceed it.)
Again, choose which propositioin you want to discuss:
1. Conveyor moves to equal the plane's forward speed or
2. Conveyor moves to stop the plane's forward speed.
These are vastly different propositions. Either can be achieved if in #2 we use a "magic conveyor" capable of unlimited acceleration and speed whether on skis or wheels or a channel filled with moving water and use a float plane.
I don't think we are in disagreement over physics, just maybe in precisely clarifying the initial conditions and givens.
Forget the tree. What if Helen Keller fell down in the woods. Would she make a sound?
Pat
Thanks for summarizing and consolidating the views. Here's the original question again for dissection...
schmism said:
a plane is standing on a movable runway (something like a conveyor).as the plane moves the conveyor moves but in the opposite direction.the conveyor has a system that tracks the speed of the plane and matches it exactly in the opposite direction.
the question is
will the plane take off or not?
The scenario states the direction and speed of the plane and conveyor but makes no statement about the effect of the conveyor. The effect of the conveyor is the question.
In order to say that the the plane won't fly one has to argue that the question states the effect of the conveyor is "to stop the forward speed".
The "Fly" camp says "I think it will fly based on the conditions stated in the question"
The "No Fly" camp says "I think the question must have more to it since I think it won't fly"
Whether a conveyor could stop a plane or not is an interesting and educational discussion, but it's not the question at hand.
I reconfirm that this question should be filed in the same category with "If a Rooster lays an egg in the center of a rooftop, what side will it roll off?" and "If a plane crashes on the border between Canada and the USA, where do you bury the survivors?"
   / will it take off? #872
Pat:
I agree about fun being most important. I didn't realize a second definition of the conveyer had been added to the original post.
I teach the slip knot method because you can contrast the quality of a noose with the bowline for beginners, and they will then remember it. I have emphasized that this method allows wrapping the working end around oneself and getting the loop the correct size in an emergency situation. Also useful is using this method to tie two ropes together when only a very short length of one is available to tie to (I forget what this knot is actually called).
Steve
   / will it take off? #873
Iplayfarmer said:
I reconfirm that this question should be filed in the same category with "If a plane crashes on the border between Canada and the USA, where do you bury the survivors?"
A better question is where do we bury the survivors of this thread!!!
Even with any negitatives it shure wuz fun most of the time, huh?
Pat ;) ;) ;)
   / will it take off? #874
[QUOTE "If a Rooster lays an egg in the center of a rooftop, what side will it roll off?" [/quote]
Who knows but there will surely be one surprised Rooster!! Will he crow is another matter.:D :D
The survivors may eventually be buried somewhere as per the wishes of next of kin or depending on the will instructions.:D :D :D That is if they are buried. They may be cremated!:D :D :D Or the body may be lost to some sort of mishap and never be recovered!:D :D :D
   / will it take off? #875
SFish said:
Pat:
Steve
Could your mystery knot be the sheet bend which is used for joining two lines together and resembles the bowline in appearance? If you use it with man made fiber rope (slipperier than natural fiber) you will want to use a double sheet bend, especially if the knot is subject to getting wet.
I was taught how to tie a bowline around my waist with one hand (by a grand mother in her 70's who had to learn it to go mountaineering with an Outward Bound group) and subsequently taught it in all marlinespike seamanship classes I taught. It can be a life saver in the outback as well as at sea.
Regarding the conveyor.. all sorts of dynamic modifications were made, assumed, employed, etc. Me, I don't have an axe to grind either way. You pick your initial conditions and assumptions (givens) and the answer is immediately apparent. The reason controversy raged so long on this topic is that not everyone (a) stuck with the given info and sometimes inserted their opinion and prejudice in place of the stated problem and (b) not everyone is as well grounded in Newtonian physics as would be a credit to their school system.
Still, on ballance a fun outing. What I don't understand is why everyone wants to bury the survivors. Haven't they suffered trauma enough?
Pat
   / will it take off? #876
However IF the conveyor runs fast enough the counter force can equal thrust (or exceed it.)Pat
I just dont see how this can ever happen with skis. I would expect the frictional coefficient would remain near constant; unlike with tires, where the hysteresis in increasingly rapid flexure continues to add resistance. With skis I can see at high speed that tremendous energy is dissipated, but I cant see how that can increasingly factor against thrust as conveyor speed rises. How does that work??:confused:
Youre right. Its the mind exercise of considering the possibilities that makes this fun. Were doing alot better on this than MythBusters.
larry
   / will it take off? #877
The prop will pull the aeroplane forward, no matter how fast the conveyer goes the aircraft will advance, the only way the aircraft would remin stationary is if wheels are driven such as a vehicle, my Cherokee will lift off at 55mph, the airspeed would be 55mph however the conveyer could be going negative 55mph, thus wheels will be going 110mph, the aircraft is going to do 55mph forward and will lift, now if you reverse the conveyer and propel the aircraft at 55mph it would still lift off and if the motor is at idle I expect it to float and land, if one revved the motor it would fly, this is the way aircraft carriers launch aircrafts, steam cylinders propel the aircraft to takeoff speed in a short distance, the engines then take over, I suspect many modern jets could not launch to remain flying in such a short distance if it was the jet engines alone.
   / will it take off? #878
"...as the plane moves..." pretty well tells us that the plane, regardless of whatever may be motivating it, changes position with respect to some unnamed point of reference. "...the conveyor moves in the opposite direction..." tells us any given point on the surface of the conveyor, regardless of whatever may be motivating it, also moves with respect to said unnamed point of reference.
In the original premise, the motion of the conveyor seems to be based on the motion of the plane, although they may be simultaneously and instantaneously controlled by some third entity about which we know nothing.
If the motion of the conveyor is indeed based on the motion of the plane, and if the motion of the conveyor adversely affects the motion of the plane, that adverse effect would have to be be conveyed (no pun intended) to the conveyor, causing it to slow. Carrying this line of thought to it's extreme, the conveyor and plane would simply come to a halt.
Anything that slows the plane with respect to the unnamed point of reference would have to slow the conveyor. That anything would include the conveyor.
As far as sounds in the woods, "sound" can be defined as either a series of waves in a medium OR the interpretation of those waves by a brain of some kind. The tape recorder would prove nothing. A CD, tape, or whatever makes no sound until the information is transformed into compressions and rarefactions in the air and those in turn are converted to electrochemical impulses transmitted through nerves to a brain which interprets them as sound.
Many of us, thanks to our love for internal combustion devices, loud music, firearms etc. and just plain age can "hear" a high pitched whistle even in complete silence due to damage to our hearing apparatus. Is that a sound or a physiological phenomenon? Similarly, we can "see" various colors by pressing on our eyes. Is that light or a physiological phenomon?
The waves in the air resulting from the falling of an object are just waves until a brain interprets them as sound.
If you connected your optic nerve to the auditory center of the brain, and the auditory nerve to the optic center, would that truly seem to be a "loud" tie you got for Christmas? And when fiddling with the equalization of your music system, could you really make the music "brighter"??
   / will it take off? #879
Egon - it was a trick question.
you don't bury the SURVIVORS.
   / will it take off? #880
Ah, but this is the debatable point in the excercize. One could argue that there is some resistance in the wheels that will counteract the prop thrust. While unlikely, the possiblility is certainly there.
MASSAGE CHAIR (A58214)
Quick Attach Bale Spear (A57454)
Quick Attach Bale...
HAY SPEAR W/ JOHN DEERE LOADER MOUNT (A58374)
HAY SPEAR W/ JOHN...
SAKAI SV414D SMOOTH DRUM ROLLER (A52709)
SAKAI SV414D...
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
GRILL GUARD & POOL LADDER (A58374)
GRILL GUARD & POOL...
