will it take off?
/ will it take off? #921
RobJ said:
Maybe they just left the parking brake on. :D
But given a power plant with enough thrust to overcome the drag it would still take off with thebrakes locked. ;)
Harry K
/ will it take off? #922
patrick_g said:
The greatest effect on the candle flame is not the oxygen concentration difference between Earth and the shuttle but the microgravity which does not support convection. If there were no ventilation fans running and everyone stayed still untill the air motion ceased then a candle flame might self extinguish by depleting the oxygen adjacent to the flame.
If the crew stayed still with no fans going they would also deplete the O2 in the vicinity of their noses and so would also self extinguish.
The question then becomes which lasts longer?
/ will it take off? #923
Uh, I think the crew, like us on Earth, inhale and exhale. When exhaling the stale air would be propelled away from the breathing person and mixed with the ambient air. Although inhalation currents are diffuse and more localized than exhalation currents the only way to get static air in the vicinity of the astronaut's noses would be if they held their breath which would result in passing out and having their autonomic system start them breathing again.
If there is no fan assisted air circulation there are bigger problems than how well the air is mixed by exhaling. It takes circulation through the atmosphere controlling system to scrub the CO2 out of the air supply and to distribute the replenishment O2.
Pat
/ will it take off? #925
I tried to eat 10 soda crackers in one minute tonight. It cannot be done, here on earth, or on the space shuttle.
/ will it take off? #927
Since the air is not static, due to crew motion and ventilation systems, the candle would probably burn (some) but erratically without the nice flame shape we are so accustomed to seeing. As previously correctly mentioned the capillarity of the wax in the wick will supply fuel to the end of the wick. Depending on several factors, including the melting point of the candle, in the absence of a molten pool of wax (held in place on Earth by gravity) the candle flame will NOT be fed at so nearly a constant rate as if it were on Earth.
Pat
Pat,
You were correct about the microgravity & convection, which completely escaped me. I'm wondering if some sort of pattern would be set up anyway based on gas expansion and mass flow stuff, but like you said, without gravity it's hard to say what would happen.
But I think you missed on the molten pool of wax, which would likely stay where it belongs simply by mutual attraction and surface tension. I'd thought of that aspect but didn't say anything in my post.
Great brain exercise, and neat how we can "enlighten" one another.
We need more smilies, like one throwing up after a bad pun!
Later,
Tom
/ will it take off? #928
Which brings us to the question of what happens if one of shuttle or space station crew should happen to suddenly become sick to his/her stomach while sleeping on board the orbiting station, literally waking in the midst of puking their guts out, followed by an episode of the dry heaves. Whither goest the ejecta, and whither goest the astronaut if overcome with retching while trying to get to the head in a weightless evironment?
Does the action of retching act to propel them about the cabin or not since they are more or less freefloating across the cabin when it starts?
BTW, for those somehow offended or upset by the question about reverse peristalsis, I'm eating lunch as I write this.
/ will it take off? #929
Later,
Tom
Without gravity the molten wax will probably be pulled into a globular shape by surface tension which will expose its bottom surface (assuming the candle stick to "define" up and down) to cooling air instead of insulating wax. Exactly what effect this more available pool of fuel with a cooler bottom would have on the flame (if there is one since a flame is a shape generated by the effect of gravity) is not so simply inferred.
Gas (CO2, H2O, unburned and partially burned fractions of wax, and such) expanding into 4 pi steradians (minus the solid angle subtended by the candle) would not have any mechanism for drawing in more air to support combustion. Without gravity, no convection.
Say you ignite the end of the candle wick with a laser to avoid disturbing the air any more than absolutely necessary. The wax and (whatever material is in the wick) is heated above the flame point for the wax and it starts to have an exothermic reaction between the wax and oxygen in the air in contact with the wick. The products of combustion slowly move radially outward away from the wick due to expansion. The only thing working to get more air in contact with fuel (assuming no drafts when the candle experiment started) is Brownian motion which is not sufficient to keep the fire hot enough to keep melting fuel for capillary action to work and the fire goes quietly goes out from lack of oxygen without the typical little smoke whisp floating up wistfully since that is not possible in micro gravity.
There may be a few minor variations but I think I described pretty much what would be observed. If the candle was kept moving then it might stay lit.
Pat
/ will it take off? #930
You sound like a CFD guy! It's a good analysis and I see what you mean, but I wonder if the "affinity" (for lack of a better term) of the wax pool for the candlestick would prevent it from going completely globular. Not that said affinity would help the combustion to continue (it would, of course, if the flame could continue).
It's amazing how much we take gravity for granted. But in an effort to wildly flog the deceased equine, I'm wondering if there would be any other transport phenomena set up just from said reaction that would not be gravity dependant. It's a stretch, I'll admit. But f'rinstance, since the reaction cannot proceed in a purely spherical manner, would a thrust be set up, and even this slight movement allow the flame to get more O2?
Ok, I'll quit. I should be doing other things anyway. ;)
Good chatting with you.
Tom
/ will it take off? #931
Must have been a real doozy of a lunch to prompt these thoughts!
It is a simple vector problem to analyze the momenta. Given the limited velocities and masses of ejecta compared to the mass of the astronaut (even with Linda Blair on orbit or the large globular guy that exploded in the Monty Python Film, "The Meaning of Life" due to overeating), it would make for minor course errors, easily compensated for since the space fliers use hand holds and foot kicks leveraged off available non-delicate objects. The greatest threat to the persons trajectory would be the swift kick in the pants they might accrue when passing within range of one of their fellows with fully functioning olfactories or the course errors that might occur due to distractions like dry heaves.
Pat
/ will it take off? #932
Tom
Likewise, good chatting with you, Tom.
CFD guy? Do you mean computational fluid dynamics? I'll take that as a complement but among other things I used to be a physicist but never actually worked under that title, instead electronics designer and many other labels. So many, in fact, that you'd be driven to one of a few conclusions; either I was a versatile sort of guy, had a short attention span, or couldn't hold a steady job. (or maybe more than one of these.) ;)
By the way... did you ever buy the cute little blue tractor? I thought it was a good idea but I'm no expert. I have only owned one tractor, 39hp Kubota with cab and HST which is up to 800 hours on the clock which are all mine except for a few minutes.
Pat
/ will it take off? #933
Indded I do mean computational fluid dynamics. I've had some training with it, but don't use it - too expensive and specialized for our company. It was meant as a complement because you obviously thought the problem thrugh more thoroughly than I. I'll make the excuse that I'm at work, but should've known better. It's not like I've never worked convection problems before.
& yes to question 2 - or almost. We shook hands last night, delivery Sat. AM. The thing was immaculate, I can't believe it's a '99. No hydraulic hose drying or cracking, nothing loose, bushings solid, cranked right over on the original battery (which WILL probably need replaced). He's giving me a complete set of filters, all the original dcumentation, and he'd changed the oil. All the grease fittings are good, I looked and looked and couldn't find anything wrong with it. Couldn't drive it, but if anything is wrond Saturday it will show up. I'd be might surprised though, he's obviously babaied the thing.
/ will it take off? #936
Yes, a dip or glass of water would work fine. But just grab a stack of 5 soda crackers and munch into them. First bite = instant dry mouth. Then if you open your mouth to say anything, POOF! the entire space shuttle atmosphere is contaminated with little bits of cracker dust, or your dining room table, depending on where you do the experiment.
/ will it take off? #937
Always used to joke with anyone getting a new car. We'd nominate him/her to host the cracker whistling contest. No one ever took me up on that...
/ will it take off? #938
IIRC part of the crew equipment on board are small, handheld "vacuums" used to suck up just such floating detritus.
Harry K
/ will it take off? #939
This thread is never going to catch up with Eddie Walkers CREATING A LAKE thread if you guys keep agreeing!:D
/ will it take off? #940
I think it's just that the disagreeable types quit posting here. I still haven't found that top, Pat, but it's around here somewhere.
Pallet of Club Car Golf Cart Seats (A64912)
Pallet of Club Car...
2014 FORD F-150 PICKUP TRUCK (A66091)
2014 FORD F-150...
2024 KUBOTA SVL97-2 SKID STEER (A65056)
2024 KUBOTA...
2013 WACKER NEUSON  LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
More info coming soon. (A64557)
More info coming...
2023 Unused Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
2023 Unused Del...
