will it take off?
/ will it take off? #801
Re: Mythbusters/airplane/treadmill
Me, being kinda slow, have trouble trying to figure out how the plane wheels can turn. Seeing as the plane is sitting on a belt but is unable to move forward and has no system to rotate the wheels the conveyor belt don't move either. Kinda a conundrum ehh. everything is sitting still.:D :D :D :confused:
/ will it take off? #802
Trying to understand....How can there be rotational acceleration of the wheel mass when it is in contact with the conveyor? The conveyor would work against that happening would it not? Even with rotational acceleration, I don't see any forces that would transfer to the plane stopping it from accelerating and taking off. All I see are 2 separate forces, the lower one gets canceled out by the wheels leaving the forces from the prop to move the aircraft forward.
But, I am listening.
/ will it take off? #803
I bow to the genius who conceived this, LMAO
/ will it take off? #804
As per the original question.
a plane is standing on a movable runway( something like a conveyor).as the plane moves the conveyor moves but in the opposite direction. The conveyor has a system that tracks the speed of the plane and matches it exactly in the opposite direction.
Under these conditions the plane remains stationary relative to the surrounding countryside. Would that not indicate the wheels are not turning as they have no mechanism to make them turn!:D Now if that is reasonable and the planes wheels do not turn the magical conveyor belt does not move either!:D It would seem to be a static situation that has been transformed into one of illusions of motion.:D
With a plane that doesn't move and a stationary runway only vertical takeoff or a heck of a strong wind that will allow vertical takeoff will ever let the plane fly!:D :D
/ will it take off? #805
Dmace said:
I am going to quote myself from page one on Nov 8, 2006 just to say "Told you so".
It is simple physics and it amazes me that so many people don't get it.
THE WHEELS DO NOT PROPEL THE AIRCRAFT, IT DOES NOT MATTER HOW FAST THEY ARE SPINNING ON A CONVEYOR BELT. OBVIOUSLY IF IT WAS A CAR, THE CAR WOULD NEVER MOVE.
Along the way the practical was abandoned for the theoretical where the conveyor belt was given magical powers and was supposed to be capable of prodigious feats. Among these was the ability to accelerate very fast (at speeds significantly below the speed of light if you wish)
Since the wheels and tires have mass and therefore inertia the conveyor has to transfer energy into the spinning wheels which results in a counterforce in the direction of travel of the conveyor. (Simple physics.)
The conveyor would accelerate as required for this retarding force to equal the thrust of the prop and the acceleration og the plane would be zero.
At some point this rapid acceleration would definitely produce relativistic velocities and the wheels and tires if not the bearings would have long since failed in the real world and and plane would be carried backwards on the conveyor.
Clearly if the conveyor was restricted to real world properties the retarding force on the plane would be such a small percent of the prop's thrust that the plane would take off and a casual observer would not detect a difference in the take off run.
Therein lies the HUGE difference between the thought problem we fussed with here vs the real world test on the "Myth Busters" TV show. Jamie's pickup was incapable of the massive acceleration required to spin up the planes wheels with sufficient jerk (third derivative of distance with respect to time or the rate of change of acceleration, again simple physics) to generate a credible retarding force on the planes forward motion.
The most surprising result was NOT that the plane flew (again simple physics) but that the bozo pilot actually thought the plane would be inhibited from taking off and he was surprised to find it took off just fine with no problem.
Pat
/ will it take off? #806
scesnick said:
BUT, if somehow the plane was driven by the wheels, then the senerio would be totally different. If the takeoff speed was matched by the conveyor, then the plane would just be sitting still ( with the wheels spinning) but no air would be going under the wings to acheive flight because the only thing moving on the plane IS the wheels.
This would be called a car...not a plane. :D :D
The Myth was busted when the plane moved forward on the treadmill. The treadmill matched the planes takeoff speed and it moved forward. After that it was just TV entertainment.
The expanding foam bit was cool to!
/ will it take off? #807
The planes wheels do not turn. The place sits in a steady state with no forward movement. The wheels have no motive power. Thereon lies the misconception of spinning masses and moving conveyor belts.
It's a simple play of words leading to presumptions of motion.
:D :D :D And this is confusing us all!:D :D
/ will it take off? #808
Since no matter how fast the wheels turn from the belt the forces are canceled out by the wheels. It is not possible for the conveyor to match the speed. Because, the aircraft {propeller} has an advantage over it, the aircraft will always accelerate. So, it is a moot point.
/ will it take off? #809
RonMar said:
With the thrust forces involved, both that of the prop moving the plane forward and the belt pulling backward, the ammount of energy needed to accelerate the wheels to a VERY high RPM is inconsequential. It just dosn't take that much force to spin up a lightweight aircraft wheel with good bearings.
Put the rear end of your car up on jackstands. Start the engine and stomp on the gas and see how long it takes to get to redline. Now remove the wheels and repeat the experiment. Even with large heavy steel or alloy auto wheels, the difference in engine acceleration with and without the inertial load of the wheels is pretty small...
We are seeing a matter of degree - HP to wheel mass. The point is it does make a difference in how long it takes the engine to rev out when rotationally accelerating the wheels. That 100 hp put into the wheels for a second or so to spin them up to 120mph is the same 100 airplane hp that could be cancelled by the conveyor quickening at a rate that accelerates the plane wheels that quickly. As you say, the lighter the wheels the easier they spin up. That just means they have to be accelerated faster to counter the plane HP, leaving none available to accelerate the plane. You run into the limits of materials very soon, but until then the plane sits still. Even totaly frictionless bearings would not prevent the conveyor resisting thrust in this way.
larry
/ will it take off? #810
Seriously?!??:eek: Have you read this thread entirely? There is no such thing in regards to "will it take off.":D
/ will it take off? #811
larry
But, it is not possible for the forces from the airplane to be canceled by the belt, because the wheels cancel the belt leaving the propeller forces with the advantage. Right?
/ will it take off? #812
I'm fascinated by the type of discussions that generate long threads (currently 78 pages)...:eek: No, I didn't read them all...just the first page, and then here. Yes, I know the answer...but won't spoil it for participants...:D
/ will it take off? #813
ray66v said:
Ok, If I see your point correctly, are you looking at the gyroscopic effect that the wheels could eventually develop if enough speed is applied???
Because rotational acceleration as I know understand it, I'm having trouble applying to this example.
This situation would not be affected by the gyroscopic properties present in the spinning wheels because the wheels' plane of rotation is not being changed - the airplane is going straight so the wheels spin in a vertical plane. If you try to lean or twist the wheel the gyro effect wakes up.
The way that a free spinning wheel can affect the plane thrust is by its resistance to having its spin speed changed. This has nothing to do with bearing friction. The plane pulls the axle forward - the earth holds the tire still - the top of the tire moves at twice the axle speed - the wheel rotates. Greater force applied across the axle/earth pivot results in greater rotational acceleration - it spins faster more quickly. A plane taking off on a normal runway rotationally accelerates its wheels until it leaves the ground. The energy that goes into accelerating the wheels to 1000rpm or so has been supplied by the engine. The wheels are a tremendous convenience, but this storing of rotation energy delays takeoff slightly. Something that didnt rotate -like skis - and had sliding resistance the same as the wheels rolling resistance would have a quicker takeoff. Moving to the conveyor idea we have a 'runway' that moves back the same speed as the plane moves forward. This means that the wheels spin twice as fast at takeoff. It takes a little more time to reach takeoff airspeed because a higher percentage of engine energy output is being stored rotationally - therefore, the translational energy required for takeoff takes longer to accumulate. This situation follows from the wheels being rotationally accelerated at a little less than twice as fast as seen in in a normal takeoff. Now lets extrapolate to a condition where the conveyor can accelerate the wheels at so great a rate that it stores rotation energy in them as fast as the plane engine can produce energy. Theres nothing left to accelerate the plane.
larry
/ will it take off? #814
Sorry for the oversight, I will try to get "with the no moot points program".
/ will it take off? #815
But, that is not possible, right?
Is this another one of those "moot point doesn't matter" discussions?
/ will it take off? #816
Noting your lack of smilies I must ask.. You did realize I was just giving you a hard time right? :confused: there are certainly moot points around here, but there was some pretty creative bull in that thread... I even produced some of it myself...:eek:
/ will it take off? #819
I think I will run the Helicopter one by my flying club's think tank, at the meeting tonight. We have several engineers and chopper drivers, whom I'm sure will enjoy a lively discussion over it.
/ will it take off? #820
The wheels never have any motive power in an airplane. They just roll freely like a trailer's wheels. It's the prop or the turbines that provide the motive power.
It's one of those trick questions meant to make the answerer feel silly for even stressing about it. It's just like these two:
1) If a rooster lays an egg exactly in the middle of a roof peak , which side of the roof will the egg roll off?
2) If a plane crashes exactly on the border between USA and Canada. Where do you bury the survivors?
Now let's spend another 750 posts giving magical powers to genetically engineered roosters so that they actually can lay eggs and further traumatizing unfortunate survivors of a tragic plane crash by planning to bury them alive in whatever their native country may be.
What if we re-framed the question to refer to a 20 foot flatbed trailer holding a brand new John Deere 5025 sitting on our theoretical conveyor and hooked it up to Mr. Jimi's new F-550 (with which I am genuinely and fully impressed, by the way) such that the truck is not on the conveyor but the trailer is? If Mr Jimi put the beast in granny gear and floored it, would he drive away?
I'll bet we'd get a lot more concensus from the question framed like this.
2019 Toyota Camry Hybrid Sedan (A66738)
2019 Toyota Camry...
2015 WINSTON TANDEM AXLE 24FT EQUIPMENT TRAILER (A66091)
2015 WINSTON...
2018 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A66736)
2018 Chevrolet...
2020 Takeuchi TL8R2 (A64911)
2020 Takeuchi...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A65053)
2018 JOHN DEERE...
2017 VOLVO SD115B PADFOOT ROLLER (A65056)
2017 VOLVO SD115B...
