will it take off?
/ will it take off? #481
jk96 said:
From the original post
"as the plane moves the conveyor moves but in the opposite direction.the conveyor has a system that tracks the speed of the plane and matches it exactly in the opposite direction"
Again, if the plane is going 200 mph forward, the conveyor is going 200 mph backwards. Nothing to negate the force of the engine thrust.
jk
Thrust does not create air movement, except for the air moving through the engine which is compressed and focused (ventury style) and only achieves success in it's thrust to movement ratio by a non-incumbered attached mass (IE. a jet with wheels). A treadmill at equal opposition will effectively nullify that process of movement of said mass. Bottom line, if the plane does not physically move through the air at the required air speed for lift it AIN'T flying. I will no longer be redundant, I promise. Show me the un-altered video to disprove me. Wife say's you still aren't buying lunch. Sorry.
/ will it take off? #482
TomKioti said:
I said nothing of the wheels (however they are conected to the plane), forget the wheels. I said if the phantom treadmill NEGATES AND MATCHES the FORWARD THRUST AND MOVEMENT of the aircraft then effectively there would be no mass (big jet) actually moving. Hence no flight properties would exist. MYTH STILL BUSTED AND WIFE SAYS NO DAGGON HAPPY MEALS AND TAKE OUT THE GARBAGE!!! Sorry folks.
Ok, lets forget the wheels. Lets bolt the plane to the MCB. (like having the brakes applied)
Question: What will happen with plane bolted to MCB?
Answer: Nothing. As soon as the plane starts pulling forward, the MCB will immediately pull it back and neither will go anywhere.
In the above situation, the MCB is indeed equaling the thrust of the engine because they are bolted together.
Now what if the bolts are removed (or the brakes are released)? The MCB no longer equals the thrust of the engine, now all it does is equal the thrust of the wheels because the engine and conveyor are no longer connected together..
/ will it take off? #483
I think we all agree that the plane needs to move forward to achieve lift to fly. The disagreement is whether or not the plane will move forward.
/ will it take off? #484
Think of the wheels like the clutch in a car. When you push the clutch in, the torque (thrust) of the engine no longer has a connection to the thrust (resistance) of the ground. Wheels on a plane are the same. With the brakes released, the thrust of the engine or the resistance of the ground no longer influence each other.
/ will it take off? #485
Why do some people keep the MCB moving and the plane stationay when it violates the original problem. The MCB only moves if the plane moves. If the plane is stationary then the MCB doesn't move. Brakes on engine rev up does plane move NO does MCB move NO. Take the brakes off does plane move? Or does MCB move to prevent plane from moving. If the MCB prevents the plane from moving the original problem is violated. WHEN THE PLANE MOVES.
/ will it take off? #486
What the heck is the thrust of the wheels? The connection of the engine and conveyer are not disconnected in the original post. They are synchronized.
I know everyones supposition is that thrust will win but, only if the treadmill will at some point lose the tracking of the wheel speed and it's attached mass. If there is a thrust = conveyer equity then I can't see it eventually moving beyond relative neatrual i.e. no flight.
/ will it take off? #487
Tom
I know you love my drawings :D So let's go back to the first of the helicopter.
In this drawing, if the wheels are attached to the treadmill. Can the treadmill prevent the helicopter from lifting off the ground and flying vertically by moving in the opposite direction? Just answer this question first.
The answer is no, the rotors of the helicopter pull it upward and it lifts off of the ground no matter how fast the treadmill spins in the opposite direction. If you argue I am wrong on this then there is no point in going any farther.
Now take the second illustration. This is no different then the first illustration. Only now, the rotars are pulling through the air horizontally instead of vertically. The very same application as an airplane.
If you answered "The helicopter will not lift off the ground" for the first illustration. Then there is no hope for further explanation. If you answered "Yes, it will lift off of the ground" Then please explain to me why it will not move horizontally as well in the second illustration
jk
/ will it take off? #488
Thank you, yes.
Ive argued this and it basically means the whole "no fly" point of view is bogus. either the plane moves, or it doesnt. Is I could just get the "no flys" to answer that one question. Yes or no. Does the plane move?
/ will it take off? #489
Thrust/resistance, its the same. Resistance is thrust in the opposite direction. Actually I should use the term DRAG instead of resistance. Would that help. drag=thrust, the plane stands still.
In my statement above, the wheels have drag, not thrust, hows that?.
Im trying to figure out why you think wheel speed has anything to do with a plane taking off? A plane can takeoff standing still if it has anough headwind. That would be zero wheel speed and the plane can still takeoff. Or the plane could be taking off with a tailwind and need twice the wheelspeed or ground speed to takeoff.
/ will it take off? #490
Quote "No energy from the engine is being "forced back into the conveyor". The only way that could be done is for the wheels to be somehow driven by the engine."
Harry, I think you should read what I actually said.
Larry
/ will it take off? #491
No, I disagree. That is a direct drive train with a much different set of rules. An aircraft is (Usually) a push or pull thrust system with many other variables at play. Also how is thrust resistance? unless metaphorically derived. If so explain please.
/ will it take off? #492
Code:
So.... your truck has wings? :)
Surely does. One covers the right front wheel. The other covers the left front wheel.:D There's a Bonnet between them!:D
/ will it take off? #493
jk96 said:
Tom
jk
That is NOT the same set of applied rules as the original post. Why is it everyone changes the argument rather than challenging the submitted points?
/ will it take off? #494
Egon said:
Code:
That's freakin AWESOME!!!
/ will it take off? #495
Resistance is a bad word for me to use. The true equivalant of thrust is drag. There are four forces involved in flight. thrust-drag-lift-gravity, .
/ will it take off? #496
Ok, heres right to the point. Does the plane move forward?
/ will it take off? #497
Tom,
how is the second illustration different. If you answered yes to my first question, which I'm assuming you have, then you have to agree that the helicopter would pull horizontally on the second illustration. Meaning what? It moves. Now, change the shape of the helicopter to the shape of an airplane and add wings. How is this different from the original question. Please tell me.
jk
/ will it take off? #498
Here’s one more scenario:
You're in a wheelchair. The wheelchair sits on top of a treadmill which can sense your speed and match it 1:1, like our plane's conveyor belt. A man lassos you and begins to pull you forward on the treadmill, with a constant force. By F = m*a, you will accelerate with a constant acceleration. But wait, the treadmill is going to pull you back, right? Tell that to the man with the rope. As long as he keeps pulling you, you will keep moving forward, no matter WHAT the treadmill does or how fast it responds in reverse. In this case, the plane is the wheelchair, the force of the rope is the thrust from the air plane's engine, and the treadmill is your conveyor belt. Since the force vector of the rope and the treadmill are COMPLETELY DISCONNECTED, and your wheels are free to spin, the only net force is that of the rope.
jk
/ will it take off? #499
IMO No. Not if the conveyer assimilates ground speed = thrust and nullifies the mass (aircraft) from achieving forward (actual) movement. I want movement of the mass in relation to static footing to achieve lift. These are rules the Wright Brothers had to overcome. They did it BUT if it was on a conveyer belt moving in opposition we'd all be taking buses and trains. Now if the convyer was in effect opposing wind at equal speed you would have a hard time stopping that plane from flying.
/ will it take off? #500
Ok, your answer is no. Lets see if you can stick to that.
The plane does not move. According to the question, the conveyor matches the speed of the plane. hence, the conveyor can not move, agree? I'll assume you agree.
The engine starts and turns the prop at full RPMS. Weve already determined that the plane does not move, hence the conveyor does not move. So now the plane sits still with its engine and prop running full RPMs and the plane sits perfectly still on the conveyor with the prop beating the snot out of the air. Can you explain to me what is holding the plane still?
that would truelly be magic if you could run a plane or jet engine up without tieing it down, all you have to do is put it on a non moving conveyor and it will stick in one place.
What is a nonmoving conveyor, its a normal runway, right, Still following? Now our plane will not move on a normal runway, hmmmm.
KOMATSU PC88MR-11 EXCAVATOR (A65053)
KOMATSU PC88MR-11...
2014 CATERPILLAR 938K WHEEL LOADER (A64279)
2014 CATERPILLAR...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
100 gal L Portable Fuel Tank (A66408)
100 gal L Portable...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
2019 K&K Trailer, VIN # 1K9PE2029KA175462 (A65563)
2019 K&K Trailer...
