SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,589
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Ok - acceleration wont be instant because nothing is, including airplane thrust. Regardless of how quickly it starts it doesnt hit - it shoves. Even an impact is not truly instant. You are right about this idea failing with time in real life. The question is how much time. Im quite positive that even a super plane can be held still for an infinite number of instants -- even longer if there is weight on the wheels during takeoff. Teflon is quite dense. Just machine gearteeth onto the periphery and mate it with a cogged conveyor. Im guessing it would remain still thru several half lifes of ozone. And thats a long time in ozone years.NorthwestBlue said:Larry,
I do understand everything that you wrote and with the Mossroad link. My premis to overcome the "Magic" is to minimize and trivialize its only strength - instant and endless acceleration. The only way that it can transfer energy to the airplane is through friction (the contact between tires and belt). The reason that the links theory fails is TIME. The reason I chose the plane that I did was to emphasize the fact that it would take very little time to create lift and therefore reduce friction and belt induced drag. I chose a design that can accelerate regardless of the state of the wheels. Rotating, stopped (brakes on), or even rotating in reverse has no bearingon the outcome.
I agree that given enough time that the MCB would prevent the airplane from taking off. Given enough friction or as you say "traction" then the MCB wins. My idea is to reduce friction or traction and to overpower any negative effects of that friction. My airplane has Teflon wheels. It can out accerate its own wheels. It will accelerate fast enough, and lift will occur fast enough that its own wheels will not be able no maintain the friction to spin up without slipping. Add additional rearward acceleration (MCB) and the wheels just slip faster. Then its just a force drag equation. The plane will fly. If you're still not convinced... I just picked up a few gallons of synthetic oil for my truck and tractor. I could use a little tubing and route a continuous drip on my Teflon wheels. Yee Haw! Come on Mr. ME -three tractor man... Git 'er done.![]()
Oh, and happy Thanksgiving.
Larry
