will it take off?
/ will it take off? #221
The trick in this "trick question" is the wording of .....Matching the speed on the airplane.
Camp 1 Feels the speed is related to air plane wheel speed
Camp 2 Feels the speed is related to air plane body speed
In the Camp 1 result, no forward motion, no fly
In the camp 2 result, forward motion is equal to conveyor speed, will fly with wheels spinning double.
Some have have stated you can't use a car or a runner as a comparrison because to power source is transferred via air vs. through traction of feet/wheels. I dissagree, the trick is the same. If you are in camp 1, car tires spin at the same rate as the convayor and won't move relitive to the ground. Camp 2 will states the car and convayor will be traveling at 25 mi/hr in oposite directions when speedometer shows 50 mi/hr.
It's all in how you understood the problem. I don't think there would be any debate if we all understood the speed referenced in the problem was air plane speed, not tire rotational speed.
/ will it take off? #222
Lardy, Lardy Me's Bye's;
Have you realized the potential launching system the aircraft carriers have missed out on! They still use an antiquated steam system do they not.
Think of airports and how runways could be shortened for takeoff!
" Its time for someone to make their fortune " Go patend the system
Aircraft crashing on takeoff occurences should surely go down
:D :D
/ will it take off? #223
:D :D
Now that would be a fun flight to Vegas!! :D
/ will it take off? #224
Ok. plane is on conveyer, plane is tied to a winch, conveyer moves foward, planes wheels turn foward as fast as conveyer spins opposite. plane sits still, turn winch on, wheels on plane spin faster, plane moves foward as winch pulls, pretend winch is engine powered prop..daaaaaaa, pretend plane is Cub, when winch reaches 50 mph, plane takes off. if winch is not released Cub is in trouble, if pretending winch is engine with prop, Cub is flying. that is my story and I'm sticking to it.. ;) ;) ;) John
/ will it take off? #225
LeadPoison said:
Anyone ever see a float plane take off going up river?
So the answer is yes the plane will take off.
A river is not matching the planes speed. Ever see a runner run off the front of a treadmill that's matching his speed? nope. Only way is if the runner speeds up and the treadmill does not.
I've only read 2 pages but it's clear the plane will NOT take off. What is a plane before it becomes airborn? It;s a car, a bus, it's a train. The wheels allow it to move across the ground to gain airspeed. If the belt matches it's intended speed, it'll never move anywhere. People said a plane uses a prop not the wheels to move. Well duh, but so what. The wheels must spin and allow the plane to move forward. If I were to push a car by hand (not powered by wheel) on the same conveyer the sane thing would happen. Nothing, the car would not go forward because the conveyer is matching the speed of the wheels. And for those that say the belt will cause enough wind...well that's just silly.
Funny how some who make the case for flight, actually make a case for no flight. :)
/ will it take off? #226
Not at all like a wheel driven conveyance. The prop, jet, turbo prop, etc is driving the plane not the wheels. Wheels will spin freely at 2x the speed of the belt as the plane LIFTS OFF!! Go back and look at a few of the links for a better explanation. Conveyor has nothing to do with it other than adding a bit of resistance from the friction inherent in bearings and the tires rolling resistance. Keep thinking about it or look at the posted links, it will come to you. No "Duh" about it, the plane flies. Nothing to do with the belt generating wind either.
/ will it take off? #227
ASSUMING THIS IS NOT A TRICK QUESTION, BUT TRULY A QUESTION OF PHYSICS, THEN
1> For those that say "It will not fly". Under normal circumstances, no conveyer, what propels a plane?
/ will it take off? #228
Please read the problem again. The conveyor is not matching the speed of the wheels. It is matching the speed of the plane.
Let's turn the problem around. Plane is sitting on the conveyor with its engine idling. Let's say the take-off speed for the plane is 50 mph. Now instead of the conveyor matching the speed of the plane the goal is for the plane to stay in one place as the conveyor accelerates to 50 mph. As the conveyor starts to move the pilot adds just enough power to keep the plane from moving backwards on the moving conveyor but not enough to move forward. This will take very little power, a few hundred rpms, because the wheels will spin freely on their bearings. Once the conveyor gets up to 50 mph and with the plane still in the same place, the pilot adds full power. The plane will accelerate down the conveyor with the wheels spinning faster and faster to take up the difference between the conveyor speed and plane speed. When the plane reaches 50 mph, equal to the speed of the conveyor going in the opposite direction, it takes off. The wheels are spinning at 100 mph.
Again, the problem states the conveyor matches the speed of the plane not the wheels. If the conveyor was matching the speed of the wheels then, of course, there would be no forward movement of the plane. But that is not the way the problem was stated.
/ will it take off? #229
755inNY,
You were right on the mark until that last paragraph.
The conveyor could match any speed, that of the airframe or that of the wheels, the plane will still move forward and take off because theres nothing holding it back. The conveyor could be going 500MPH in the wrong direction and the only effect will be on the wheel bearings and tires.
Its really that simple, NOTHING IS HOLDING IT BACK. the wheels are freewheeling on conveyor, as long as the prop is pulling it, it will move forward.
/ will it take off? #230
So, do you think if the conveyor was inclined to 15 deg the plane would fly? This would cause about 25% of the weight of the plane along with the conveyor to try to roll it backwards. I don't see how in one instance it can gain forward motion and then with a slight incline it can't.
/ will it take off? #231
If the conveyor were inclined the plane would act just like it would on an inclined runway. The only thing different about taking off from the conveyor verses taking off from a conventional runway is the speed the wheels are turning, Nothing else changes, and if the wheels are freewheeling, they wont effect the movement of the plane at all.
/ will it take off? #233
O.K. Last try (of course, I'm lying :p)....
Read these articles at the straight dope:
The Straight Dope: An airplane taxies in one direction on a moving conveyor belt going the opposite direction. Can the plane take off?
The Straight Dope: "A plane is standing on a runway. . ." No, it's not. Here's why.
In the question originally imposed, it seems like the plane will fly. I thought it would, too. But no one takes into account the force that the conveyor will exert on the plane. Read the first article... it supports the IT WILL FLY train of thought(even mentions roller blades, ropes, etc...). Then read the second article. It shows where most folks forget about the force exerted by the treadmill. If the treadmill was built to continue to accellerate to an infinite speed, the plane stands still.
/ will it take off? #235
I think you are getting what drives the plane and what makes it fly mixed up. The prop, jet is simply moving the plane along the ground, keep it under the stall speed and it just rolls down the road.
What would happen if you used the same senerio on a jet powered car? No wheel power. Would the car move forward if the conveyer was going in the opposite direction? In your case the car would move forward.
To fly a plane needs air moving across the wing, it doesn need a prop or jet. Ever seen a glider? :)
/ will it take off? #236
The plane rolls on the ground before it can gain airspeed and the wing can create lift. So the belt matches the speed before it leaves the ground, no air moving over the wing.
Now a helo would fly!! :D
/ will it take off? #237
The original question says "STANDING" which implies no movement. In that case, no movement = no flight.
But assuming no trickery in the question, can a plane take off from a conveyer belt if the belt matches the planes speed, but in an opposite direction.
ABSOLUTELY!
NO. 1
If a car was on a conveyer belt and was running 100mph according to the car's speedometer and the belt was moving 100 mph in the opposite direction, then the car would not move. It gets in propulsion from the ground, or conveyer belt in this case.
NO 2
Now although it may not be possible, imagine a plane pulling that same car and relative to the ground, they are both now moving 100 mph and the con. belt is still moving 100 mph in the opposite direction.
So why is the car not moving in no. 1, but it is in no. 2? In no. 2, the plane which is pulling the car is using AIR to pull it forward. Yet in no. 1 it is using it's wheels to provide acceleration. Therefore, in no. 1, of course it would not move relative to the ground.
SO FOR THOSE WHO THINK THE PLANE WILL NOT MOVE, DO YOU THINK IT GETS IT FORWARD MOVEMENT FROM IT'S WHEELS. :D IN THAT CASE, AS SOON AS THE PLANE LEFT THE GROUND, FRICTION WOULD SLOW IT BACK DOWN AND IT WOULD RETURN TO THE GROUND. THAT'S LIKE PUTTING WINGS ON A CAR. WHEN IT GETS UP TO SPEED, IT WILL LEAVE THE GROUND, BUT IMMEDIATELY RETURN BACK TO THE GROUND.
Now back to the original question, the plane gets it's propulsion by pulling itself through the air. Air provides the stationary resistance for the plane to accelerate against, The conveyer belt would have no relevance to the planes acceleration since it uses air.
If you held a radio controlled plane in the air and it was revved to full throttle, would you feel it pull? For those that think the wheels affect it, I guess you think it would not pull against you since it's wheels aren't touching the ground.
Imagine the cub scout wooden rally cars? Strap a large bottle rocket to it and place it on the con. belt. Will it move with propulsion coming from the bottle rocket? YES Now detack the rocket and attach motors from a radio controlled car to the wheels. Accelerate the car with the remote control motors attached to the wheels. Will it move now? NO
If a fish were swimming 3 mph directly against the flow of water which is flowing 3 mph in the opposite direction, you could watch the fish swim "in place". (Kinda like those swim at home pools, where the water is flowed through a short pool and you swim against the water) Now a fisherman catches that fish from an upstream direction. As he reels in at 3 mph, the fish moves closer to him at 3 mph. It moves now because it is getting it's moving force from something other than the flowing water.
So as long as the plane gets it's acceleration from something other than the "flowing water", it is going to accelerate and fly.
/ will it take off? #238
Is the speed of the plane that is supposed to match the conveyor belt its airspeed or its ground speed?
As has been stated, if the airspeed of the plane is high enough, it will fly even though the ground speed may not give that impression.
If the wind blows hard enough, a parked plane will lift off the ground. If tethered, it might "fly" in place. If not, it will likely flip over and break.
If the wind is blowing hard enough and a plane can fly slow enough, it could be seen to move backwards by an observer on the ground -- a 50 mph plane flying directly into a a steady 60 mph wind will have a ground speed of 10 mph backwards.
/ will it take off? #239
PHP:
I`ll be glad when this plane runs out of fuel.
Running out of fuel may be difficult as the fueling truck can park right alongside and just keep filling it up.:rolleyes:
Now if someone coulkd jimmy up the conveyor belt so it can't move maybe we could get lift off!:D
/ will it take off? #240
If the plane has enough power to take off a normal 15 degree slope, it also would on the coveyor. The airframe doesn't care one wit what speed the coveyor is doing, how fast the wheels are turning, how steep a slope, not even what direction the belt is turning (see my last post). All it cares about is airspeed and that will develop as soon as the engine fires up.
Remember that the plane is not fastened to the belt in any way at all other than whatever bearing friction exists and this being a theoretical thing, they are ideal bearings, i.e., frictionless.
Harry K
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
CASE 590 SUPER M SERIES 2 BACKHOE (A65053)
CASE 590 SUPER M...
2005 Dynapac CT262 Sheep's Foot Compactor (A62679)
2005 Dynapac CT262...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2014 KENWORTH T370 ROAD TRACTOR (A65054)
2014 KENWORTH T370...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
