Will it fit on my trailer?
   / Will it fit on my trailer? #1
westbrooklawn
Platinum Member
North Carolina
kubota L3400HST
OK guys... looking for some help here. Will a kubota L3400 with FEL and Box Blade fit on a 6.5" X 14" landscape trailer? I know the weight is OK since I have dual 3500# axles, and I know the width is OK, but how about length?
   / Will it fit on my trailer? #2
west; I may be wrong, but I think your machine is comparable in size to a Class III Boomer?[TC35-45]. If it is, I'd say your a little short. Check out my post in Owning and Operating under "Some constructive critisiism please". That's a 20' trailer filled up. I think I'd spring for an 18' minimum if your tractor is as big as I think it is. /forums/images/graemlins/grin.gif
   / Will it fit on my trailer? #3
I dont know the wheel base but you will probably have to throw the Fel over the tounge or up in the air. My BX I was told would not fit on an 8' trailer. It does with FEL and BB. FEL on the tounge gave great balance to the single axle trailer.
Good point... I don't want the 60" bucket to hang too far over the tongue because it could hit my truck tailgate while making turns. Will just have to experiment....
   / Will it fit on my trailer? #5
westbrooklawn,
You should check with your DMV to make sure you are allowed to hang your fel bucket over the front of the trailer. In PA your not allowed to do that. I have a 20' trailer to haul my L3430 w/backhoe. It works great and everything is on the trailer.
Bill
   / Will it fit on my trailer? #6
If it fits your trailer thats a good thing ! But You mentioned it's a landscape trailer . Does it have the typical expanded metal flooring ? If so, You might want to think about putting on something a bit stronger . The expanded metal will soon stretch and break the attaching welds under the weight of your tractor . John
   / Will it fit on my trailer? #7
Attached is a pic of my L3830, which I think is almost identical in wheel base to the L3400, with BH. It is a 20ft trailer with 4ft dove tail. The dove tail starts at the back of the fender. As you can see, it fills up the 16ft of space on the deck, so you will be a little short with a 14ft and a grader box, unless you can let something hang over the tongue.
Chris
Floor is treated 2 x 6 so that is not a problem. The ramp tailgate is expanded metal and I will probably need to reinforce that depending on where the wheel tracks in relationship to the angle iron on the ramp.
Good points about checking with the DMV. If I have to hang the bucket over the tongue it will only be for a short time... I will definitely have to get a bigger trailer if that is the case.
Chris -
Thanks for the picture... it puts things into perspective. Actually the L3400 is about 9" shorter than the 3830. That still doesn't give me enough room on a 14' trailer with any type of implement on the back. We will see exactly what the deal is tomorrow. I will post back.
Dick
   / Will it fit on my trailer? #10
Another option you can take is to remove the BB and hoist it into the truck with the tractor if that is an issue with the vehicle code.
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2018 FREIGHTLINER COLUMBIA GLIDER TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2021 Kubota KX033-4 Mini Excavator (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 Kubota...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
