Will Cat 2 Pat's Quick Hitch Work With Cat 1 Implements?
   / Will Cat 2 Pat's Quick Hitch Work With Cat 1 Implements? #1
Bladerunner6
Elizabeth City, NC
John Deere 950, and John Deere 5065E w/553 Loader, John Deere Gator XUV 825M
The subject sort of says it all. I have a JD 5065e tractor, which is a Cat 2. However, all my implements are Cat 1 left over from my old tractor. The old implements work on the new tractor, using the lift arm sleeve adaptor that slides over the lift pins.
Will the Pat's Quick Hitch work with the Cat 1 lift pens with the Category 2 to 1 lift arm sleeves? Will the lynch pins hold the adaptor sleeves on the implement lift pins?
Bottomline, I am trying to figure out which of the Pat's Quick Hitches I need to buy?
   / Will Cat 2 Pat's Quick Hitch Work With Cat 1 Implements? #2
Might, then again might not.
I bought Cat 2 PEC for my M4700. Most Cat 1 things it fits fine, but on my Cat 1 tiller the spacing is too tight and I have to swap them out.
You might need a pto-adapter to lengthen your present pto shafts. Get the right # of splines.
   / Will Cat 2 Pat's Quick Hitch Work With Cat 1 Implements? #3
Get some of these:
Category I to Category II Draw Pin Set of 2
Bruce
   / Will Cat 2 Pat's Quick Hitch Work With Cat 1 Implements? #4
All of my CAT 1 implements fit just fine on my Pat's CAT 2 hitch.
That said:
>I bought the weld-on Pats so that no PTO or hydraulic top link problems exist.
>You definitely need to use sleeves on your CAT 1 pins. Plus, the CAT 1 washers won't fit on CAT 2 pins. (You can make your own from washers - grade 8 work best).
2019 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2019 Chevrolet...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
UNUSED AGT SAWMILL (A51244)
UNUSED AGT SAWMILL...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
UNUSED MOWER KING SSB72 BOX BROOM (A51244)
UNUSED MOWER KING...
2019 John Deere 8295R MFWD Tractor (A50657)
2019 John Deere...
