Will an M6800-M7040-etc fit on a 14' trailer with the bucket off?
   / Will an M6800-M7040-etc fit on a 14' trailer with the bucket off? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
A friend wants to know and I'll bet someone here knows the length of an M6800--M7040 or similar with a loader on. He figures to put the bucket in the back of the truck so that should make it within a few inches. He also thinks he could hang the loader arms off the edge a few inches. I wish he had a longer trailer.
The tractor itself is 11'3" and I can't find anywhere the loader length is mentioned. Any help appreciated.
   / Will an M6800-M7040-etc fit on a 14' trailer with the bucket off? #2
I just measured my m7040 and without bucket i came up with 15'. my tractor is parked indoors with a grapple on it in the dumped position.. I measured from the skid steer quick attach to back of rear tire. Hope this helps.
   / Will an M6800-M7040-etc fit on a 14' trailer with the bucket off? #3
That is a LOT OF TRACTOR to put on a 14 foot trailer. My concern might be how many axles the 14 foot trailer has under it and it's capacity.
Putting the tractor "on" the trailer might not be the biggest problem. Getting the weight far enough forward to keep the trailer from swaying as it goes down the road and putting the trailer, tractor and towing rig in the ditch. At speeds, a swaying trailer with that type of weight is almost impossible to correct.
Seriously consider another option, such as a longer trailer. (longer and heavier duty probably)
David from jax
He's pretty determined. Wants to put it on backwards so the weight is right. Says he got two axles with elec brakes all around so it must be a skid steer trailer. I tried to get him to rent a trailer at U-Haul or somewhere but he didn't want to do that.
Grader guy--thank you for measuring.
   / Will an M6800-M7040-etc fit on a 14' trailer with the bucket off? #6
We want pictures!
It should fit.
Here's my M4700 (which is listed as about the same length on Tractordata.com) on my 16+2 Hudson trailer.
513395d1498427729-will-m6800-m7040-etc-fit-20140427_103025-jpg
Bucket resting over the trailer tongue a bit.
M4700 wheel base 78.7"
M7040 wheel base 80.7" to 84.4"
My problem was the width, I had to narrow my rears down to fit between the fenders, that's why the tires are on backwards.
/edit - trailered it about 900 miles in 16 hours with no problem.
And in the picture it was not yet chained and strapped down for transport.
newbury--Thanks. A picture is worth a thousand words. Well know by tomorrow afternoon and I'll report back
   / Will an M6800-M7040-etc fit on a 14' trailer with the bucket off? #8
We want pictures!
It should fit.
I wasn't at all surprised that it fit, and have no doubt your 18 foot trailer did a beautiful job of hauling it. The problem isn't fitting it on a shorter trailer, it is hauling it once it gets on the trailer. Typical trailer rules require about 60% of the load on the front of the trailer. That is what I am concerned about, and what that much weight is going to do to the towing vehicle once it starts to fishtail.
Sixdogs,
Depending on how far forward he can get the tractor tires, he might be better off putting the tractor on forward facing. Kind of depends on what he is towing it with. If he can elevate the loader over the tongue and keep it high enough not to hit the towing vehicle, and can figure out a way to support it (such as a headboard), then the weight on the front might be better going on forwards.
Hope he has good luck with it,
David from jax
Sandman...wouldn't most of the weight be in the back end and backwards be a better idea? Explain that thinking some more. There is a railing thing up front that might prevent it going too far forward. Plus, I think I can make suggestions but they probably won't be listened to.
   / Will an M6800-M7040-etc fit on a 14' trailer with the bucket off? #10
I don't know the exact makeup of the current axle weights, meaning which is heavier if weighed. However, if you pull the front wheels up to the front of the trailer, and the loader overhangs the tongue, then that puts the center of gravity further forward. (with bucket it does it more). If you back the tractor on, assuming the rear is heavier, you still have a longer distance to the rear of the load from the center of the trailer. Meaning the center of mass is further back due to the loader sticking out the rear of the trailer. Basically you can move the center of weight further forward if the loader overhangs the tongue.
Rear tires are made to handle more weight, but do they weigh more? Only way to know for sure, is to load it both ways and weigh it.(You can do this at a Catscale at most truck stops) Probably cost $10 plus $1 for a re-weigh)
David from jax
2018 John Deere 6215R MFWD Tractor (A53342)
2018 John Deere...
New Land Hero Mini Excavator (A53002)
New Land Hero Mini...
HARDEE RD72M LOT NUMBER 158 (A53084)
HARDEE RD72M LOT...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A53472)
2022 New Holland...
BESTWAY AG VSK50 LOT NUMBER 80 (A53084)
BESTWAY AG VSK50...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
