Will an L3130 HST operate a 5' rough cut?
   / Will an L3130 HST operate a 5' rough cut? #1
GeauxLSU
Bronze Member
Atlanta burbs
Kubota L3130
OK, not sure where to post this and couldn't find anyting in a search and I'm as newbie as they come so here goes.
I finally bought a tractor, an L3130 (with FEL got it with 14 hours from an auction :) ). I liked this tractor in that it was the only type tractor I had ever driven (friend let me borrow his to rough cut about 4 acres of over grown pasture). He had a 5' Bush Hog brand rotary but his was GST. Reading the specs on most 5' rough cuts it appears they have a 25 pto hp minimum (some more). The HST on this model drops the PTO hp down to 24.0. Is there really no 5' rough cut I can use with this thing? :confused: If I have to drop down to 4' I will regret not getting a bigger machine and chalk this up as one of many of my expensive "life tuition" payments.... :(
   / Will an L3130 HST operate a 5' rough cut? #2
GeauxLSU
Go with what you have! I happen to have both a 5' and a 6' shredder and use both behind my L3130 and don't have any problems. I do tend to use the 6' only on grassy areas. I should sell the 6' and put the money toward another implement but just haven't got around to it.
Vernon
texbaylea said:
GeauxLSU
Tex,
Well that's the thing. I have not purchased a bush hog yet so I don't have anything (just the tractor). :eek:
I guess some more useful info would be that 'MOST' of my cutting will not be very tough stuff. Old overgrown pastures etc., but no doubt I want to be able to clear some wooded areas and would like it to be able to cut decent saplings etc... but again, if I bought the wrong animal, so be it. Just don't want to tear up anything. :(
Thanks again.
   / Will an L3130 HST operate a 5' rough cut? #4
I have been using a Woods BrushBull 600 for 6 years now. Tractor is a 3410 hst and there is no shortage of power. I think your 3130 is fine.
jb
   / Will an L3130 HST operate a 5' rough cut? #5
I use a 5 foot rotary mower with no problem and my PTO power is less than yours, I used a 5 footer on my Ford 8N for 18 years. If it gets real thick and heavy I have to slow down but I can get through it.
   / Will an L3130 HST operate a 5' rough cut? #6
I use a 6' rough cutter behind my L3130 HST with no problems as long as the grass is not too wet or thick. If it is I just slow down a bit. If you will be using it to clear out thick areas on a regular basis, a 5-fter would give you a little more power.
   / Will an L3130 HST operate a 5' rough cut? #7
It will work jus fine. Be aggressive on the amount of times you mow and you should be fine.
   / Will an L3130 HST operate a 5' rough cut? #9
I have a 5' King Kutter on my L3430 that runs just fine. I am sure the L3130 would be the same. A dealer near here has a rental L3130 with a 6' Rino Hog.
ksmmoto
   / Will an L3130 HST operate a 5' rough cut? #10
I run a 6' MD172 behind my L3400 (27.5 pto hp) and don't have any problems.
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A48082)
2019 Club Car...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
2022 MGT CM11CUFT S/A Towable Concrete Mixer (A49346)
2022 MGT CM11CUFT...
2021 Bell B30E Off Road Dump Truck (A50860)
2021 Bell B30E Off...
