Will a modern implements MR25 york rake work with a Kubota BX2350?
   / Will a modern implements MR25 york rake work with a Kubota BX2350? #1
hydrasports
Preston, CT
I don't have a tractor
I have been looking for a sub-compact 5' york rake for my BX2350. Would you all know if a modern implements MR25 work with a this tractor?
Thanks,
Steve
   / Will a modern implements MR25 york rake work with a Kubota BX2350? #2
According to York's website, the MR2 series is good for cat 0 or cat 1 hitches on tractors up to 20 hp, so yes, at 17.7 pto hp on your BX2350, it looks to be a good fit. Weight of the MR25 is 132#. HTH
   / Will a modern implements MR25 york rake work with a Kubota BX2350? #4
A 5' rake is what you want for a BX. You should measure your lift arm height with the 3 point hitch all the way down which I think is around 8 or 9 inches then measure the implement. I have seen some implement that the 3PH will just barely go low enough to hook up to. When you run over a bump the implement will come off the ground. I would consider a rake for a Compact. I have a Woods LR72, it is a little big for the BX but it lifts it pretty good. It will try to drag in some places that are real uneven. If you go with a rake designed for a compact and you get a larger tractor it will work.
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2024 JOHN DEERE FC20M LOT NUMBER 74 (A53084)
2024 JOHN DEERE...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
John Deere 1018 10ft Rotary Cutter (A51573)
John Deere 1018...
