Mowing Will a John Deere 4100 handle a 72" mower?
   / Will a John Deere 4100 handle a 72" mower? #1
Towmater
John Deere 4100
Hi all, Towmater here! I'm considering getting a 3point hitch finishing mower. Will a John Deere 4100 with the Yanamar diesel engine be able to handle a 72" width deck or is that just to much for it? Thanks much!
   / Will a John Deere 4100 handle a 72" mower? #2
I bought this 4100 new in 99 with 60 inch finishing mower, the dealer added the weights because in his opinion it would not be safe without them. I mow about five acres every week and in my opinion the 60 inch is about all this tractor can handle. In heavy grass I have to go very slow to get a good cut.
Larry
Thanks Larry, thats what I thought I was going to hear. I've mowed with several gas 20hp w/60" and even though this one is diesel I figured 72" would be to much for it. Thanks for the help! Isn't the 4100 a great tractor though?
   / Will a John Deere 4100 handle a 72" mower? #4
I love the tractor and I have wished many times I had a wider mower but I have one section that I mow that gets plenty of moisture and it reallly stresses the tractor. But for a 20 hp tractor I am amazed at the things I can do with it but the 16 hp pto is a little light for the larger mower. Does yours have a front end loader? If so what is the model number?
Larry
Yes, it has the 410 Loader that came with it. I've only have had the tractor for about a month but it has impressed me so far. I bought it to use mainly with the load, not for mowing. I'm spoiled, I have en exmark lazer Z I mow with. I just used the loader in the driveway today in 4 wheel drive to dig up some grass in the center lane of the driveway. I'm very impressed with how well it works for the size of tractor. It is the perfect around-the-house tractor for the odds and ends. Next mission is to find a 47" snowblower for the front of it.
   / Will a John Deere 4100 handle a 72" mower? #6
I wish mine had a loader but new they are just to expensive, the day I bought the tractor in 99 the dealer offered to add loader for $1500 but I did not think I could afford it now John Deere wants around $4500 to add loader and the tractor already has the hydraulic lines and joy stick.
I am not an expert on diesels but I have noticed the 4100 has a small fuel filter and if my tractor seems to be losing power that is usually the problem, I change it every spring when I change oil, etc. and keep one on hand just in case.
Larry
I saw a 410 loader sell on eBay for 1,900 and it was rough and beat. You would be better off to sell your tractor and buy another one with a loader on it. Thanks for the fuel filter tip and it is very small but at least easy to access. I read another post of mine and a guy told me to use the JD fuel additive to cut down black smoke at start up. Do you know if the motor has spark plugs or just injectors? Maybe they suggest using injector cleaner if running rough. I'm sure 99 year would have injectors since unit pumps are mainly used on diesel trucks.
   / Will a John Deere 4100 handle a 72" mower? #8
I agree on selling and buying another a person could get more hp and a loader probably without spending to much more than deere wants for the loader. I think mine has injectors, the only thing that has been done to mine since it was new was one of the safety switches went bad about three years ago and I had to take it back to the dealer because I could not determine which one was bad.
Larry
   / Will a John Deere 4100 handle a 72" mower? #9
All diesel engines have injectors, do you mean glows plugs rather than spark plugs? (diesel engines do not have spark plugs).
Oops, good eye kennyd! Yes that would be glow plugs. Since your in on the conversation kennyd how many glow plugs are the 4100's built with? Are they built with any? I'm assuming maybe three? I know I've read the block heater is an optional item that would have to be purchased. Hey, also for my own knowledge.... do all new tractors still use a traditional fuel injection pump, or are they switching to EUP electronic unit injectors like Mack did several years back?
2019 Bobcat E26 (A50120)
2019 Bobcat E26...
2015 CHEVROLET CAPRICE POLICE CAR (A52141)
2015 CHEVROLET...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2013 Chevy Silverado 2500 HD (A52748)
2013 Chevy...
2016 Toro Pro Force Towable Blower (A50322)
2016 Toro Pro...
