Will a Hydraulic pump pump water ?
/ Will a Hydraulic pump pump water ? #1
FredH
Platinum Member
Ruch , Oregon
N.H. TC-30
Just a curious question , Not planning on trying or doing . As the title says , Would a Hydraulic pump , like on a wood splitter , pump water in a open system ?
Open system meaning a resevoir to draw from but pumping out a different way , not back into resevoir .
Have no idea " Why " this got stuck into my brain , But google researching did not produce much other than the link below mentions a water based fluid that
a pump can be derated in rpm's thus decreasing pressure in the " Fluid type and Viscosity " section .
The Right Pump for the Job
Fred H.
/ Will a Hydraulic pump pump water ? #3
I'd say it will briefly. Then it'll either seize up from no lubricant or rust up.
Figured it would for a bit anyway , since that link mentions the requirements for different seal types with different fluids . The bigger question is WHY this was even in my brain to begin with ???????????? Have no idea were it came from , woke up this morning with this question rattling around the vast emptiness of my head :confused3:
Thank's :thumbsup:
Fred H.
/ Will a Hydraulic pump pump water ? #5
We have some hyd pumps at work and have been told in the event of a catastrophic fluid loss water could be used....it'll work until it doesn't if that makes sense. These operate at 10,500 psi and would be considered life safety.
/ Will a Hydraulic pump pump water ? #6
What are they for?
/ Will a Hydraulic pump pump water ? #8
Hydraulic extrication tools. Think jaws of life. Trade name TNT tool was the company that made that claim
Brett
A gear pump is not ideal for water, but there are many "water based" hydraulic systems. There are usually some soluble oils added for lubrication.
One limit for pressure systems would be cavitation, and subsequent erosion of metal parts. For "open systems of fluid transfer, as long as there is some fluid to limit metal wear, water pumps by positive displacement as well as it does by inertia.
Don't expect long service life from an unadapted hydraulic gear pump though,
/ Will a Hydraulic pump pump water ? #9
Especially at 10,500 psi. Said it'll work but I would fully expect it to trash the pump pretty quick. Like I said it'll work till it won't. Then it'll be done
Brett
/ Will a Hydraulic pump pump water ? #10
One would not expect such high pressures in an "open" fluid transfer application.
Pressure drop as a fucntion of line footage would be "pumping to the moon". ;-)
/ Will a Hydraulic pump pump water ? #11
I don't know what your talking about. Only that the tools operate at 10,500 psi. It's a bunch and precautions are taken to protect the hoses in the event of a failure....which would be real bad
Brett
/ Will a Hydraulic pump pump water ? #12
Brett
Brett
Please read the original post. It will give you insight to the topic.
There are no 10ksi systems mentioned here.
In fact, a typical tractor or wood splitter will never see over 3ksi. There are pressure relief valves to limit ultimate pressure.
What are talking about? extremes perhaps...
/ Will a Hydraulic pump pump water ? #13
I have a friend who used to be a mechnaic on a merchant ship. He told me that when the weather is bad and you lose all oil in the engine you put water in it to keep running.
/ Will a Hydraulic pump pump water ? #14
Brett
A system like the jaws of life was mentioned and those do run at 10k psi.
Brett
Aaron Z
/ Will a Hydraulic pump pump water ? #15
Aaron Z
Apparently I misread the initial post. I was under the assumption that the OP was asking if they could operate on water. I have since been corrected.
Brett
/ Will a Hydraulic pump pump water ? #16
Warning - thread Hijack in progress.
Brett
Hey Brett,
I would get the specifics of that claim in writing.
I was told something similar by the Holmatro dealer years and years ago but his take was that the pickup tube on the Power Units did not go all the way to the bottom of the reservoir (and Holmatro runs on Mineral Oil) so in a pinch we could add water to the PU and float the Mineral Oil up to the pick-up tube. I don't think he was ever advocating actually letting water enter the system.
(Side Note - Hurst uses Phosphate Ester based fluid, not sure what TNT runs but I will be soon after we get some of the new battery hydraulic ones)
While I would never spare any piece of equipment over a persons life & I agree that when life safety is on the line the philosophy of "It will work till it don't" is acceptable risk - you need to be aware of who's going to be on the hook for the destruction of several thousand dollars of extrication equipment.
One of the first things you're taught is "Always have a Plan B", the next thing is "When Plan B becomes Plan A, think up a new Plan B".
I wouldn't take that trick out of my toolbox but I would move it very very far down the list and I would be very sure I understood all the ramifications of that action.
Like I tell the cadets in our academy - I'm not fussin, I'm not preachin, we're just talkin and you have to decide for yourself.
Be safe Brother.
/ Will a Hydraulic pump pump water ? #17
In WWII there were cases of aircrew peeing in the hydraulic system to get the landing gear down, it will work in an emergency, and only until your mechanic gets his hands on you.
/ Will a Hydraulic pump pump water ? #18
Hey Brett,
Be safe Brother.
That's some great info. Makes since that the oil would rise above the water added. The way the tech said it, mind you this was 13 years ago was that in a bind it'll run on water. I never asked for more info, just assumed he was boasting his product. He also gets the big money to repair or replace the damage though. At my full time job we run holmotro and always have atleast one extra set of tools coming. As for the one making the call to add water in a bind or anything else that's out of the norm, it falls on me. I get to be in charge of the daycare. Like you said, there's nothing on the truck that I wouldn't risk for a life, just have to be able to justify it and be accountable.
Whip these cadets into shape. My friends that are instructors are telling me there is a class for them about teaching millenials.
Brett
/ Will a Hydraulic pump pump water ? #19
We're a combination system with Paid & Volunteer - our last academy had everything from 16 to 65 and finding ways to convey the same information to fit everyone's learning style gets to be interesting. I might have to track down some of those classes. LOL
Stay Safe Brother.
/ Will a Hydraulic pump pump water ? #20
I always wondered just the opposite, namely, whether a pressure washer could be converted into a gas-powered hydraulic pump...
ATS ME18 Mini Excavator (A64047)
ATS ME18 Mini...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
2009 Peterbilt 367 Flat Bed (A64047)
2009 Peterbilt 367...
2011 Ford F350 Service Truck (A63116)
2011 Ford F350...
2011 John Deere X540 Lawn Mower (A63116)
2011 John Deere...
