Mowing will a 72 mid mount mower fit the 4100
   / will a 72 mid mount mower fit the 4100 #1
FORT4100hst
JD 4100HST
Hi guys, I am brand new here. I just bought a 2000 4100HSt from Craigslist. Came with a 72" mower on a pallet along with blades, pwr broom etc..when i went to install the mower, I found there were zero hangers, or brackets under my tractor. The local dealer seemed to be totally without answers on how to solve this issue. Any help will be appreciated. I have 3 acres that is getting taller by the day and i am bummed out that what i bought is not ready to rock the field :(
   / will a 72 mid mount mower fit the 4100 #2
That really sucks when you make a purchase that doesn't work out.
I'm sure 4100 owners will chime in as to if the MMM will even fit under your tractor. I don't think it will, but I have no experience with that little Deere.
Can the seller help you out? I assume he bought the mower...
However, the 4100 has 16 PTO HP, so you'd probably be better off with a 60" mower anyway...and I suggest you consider a rear finishing mower (you are mowing lawn, right? MMMs and RFMs are not for field use...you'll tear them up).
Good luck, Bro...and welcome toTBN!!
   / will a 72 mid mount mower fit the 4100 #3
The 72" mower will not fit your 4100, it was only sold with 54" or 60" MMM.
   / will a 72 mid mount mower fit the 4100 #4
Kenny is right. That 58 inch wheelbase can not provide sufficient clearance between the tires to properly fit a 72 inch deck.
So there is no way to make this deck fit?
That is really sad!
The field I need to get under control is smooth..
The tractor was sold as including mower, broom etc..but nothing was mounted. I really needed a loader to landscape our new property, and a strong mower for the rear as my 42 Craftsman lawn tractor would simply get killed out there.
I hope the 4100 will end up being a good machine. Do you think there is any trade in value on the 72 towards a 60?.would that be at a dealer or private..
Any advice would be appreciated!
PS.... The 4100 has NO brackets under it. what do I need to hang even the 60" deck? woudl these come with the new deck, or do I need to buy an install kit? how is the deck lowered and lifted with the 4100?
THANKS!
   / will a 72 mid mount mower fit the 4100 #6
The install kit is always extra. One mower deck may fit several different model tractors but require a different kit for each one. The typical lift method is either by the using the three point hitch lift control linkage or a separate optional hydraulic cylinder controlled with the loader joystick.
   / will a 72 mid mount mower fit the 4100 #7
There is no way to make it fit...
There are several things needed to make it work, and when new it all cost a little under $3000 for everything including the deck. The 72" deck might be worth $1000, but if you don't have the parts to attach it and don't know what it fit's then it would be a tough sale. It is lifted from the 3PH lower arms.
Below are pictures of the hardware to mount a 60" on a 4100.
I might suggest you look for a 5' RFM (rear finish mower) so you can get mowing ASAP.
I have found a deck 4110/15 from a 2006 4115. Would you happen to know if this would fit on the 4100?
Thank you!!!
   / will a 72 mid mount mower fit the 4100 #9
Thank you!!!
As long as it's not a 72" deck then yes. Some hardware is different though.
   / will a 72 mid mount mower fit the 4100 #10
You can always just switch to a 3point finish mower to solve the issue.
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
Ground Breaker X Backhoe BH80X 3 Point Hitch Attachment (A51573)
Ground Breaker X...
JOHN DEERE RC7 R LOT NUMBER 224 (A53084)
JOHN DEERE RC7 R...
2025 New/Unused Wolverine Brush Cutter (A51573)
2025 New/Unused...
2018 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2018 Allmand...
2023 Chevrolet Express 2500 Cargo Van (A51692)
2023 Chevrolet...
