Will a 72" deck fit a ZD1211 that originally came with a 60" deck?
   / Will a 72" deck fit a ZD1211 that originally came with a 60" deck? #1
90cummins
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
Just wondering if they are interchangeable.
90cummins
   / Will a 72" deck fit a ZD1211 that originally came with a 60" deck? #3
Doesn’t the 72 have the wider front axle as well?
   / Will a 72" deck fit a ZD1211 that originally came with a 60" deck? #4
The 72” frt axle is Wider.
Has anybody priced a complete 72” SD deck assy ?
I’m wondering how bad expensive they are .....
   / Will a 72" deck fit a ZD1211 that originally came with a 60" deck? #5
I kinda doubt it’ll work. Just because both options were offered doesn’t mean everything else is interchangeable. Is there room to put the deck in for starters. A 72” has 5” longer blades so the deck is going to be deeper to clear them. My 72” ZT has a 59” wide wheelbase. I kinda doubt they’d stick a 60” deck in the same frame and only let it stick out 1/2” per side.
   / Will a 72" deck fit a ZD1211 that originally came with a 60" deck? #6
I believe it will. I have a 72 RD on my ZD1211. I don't think Kubota would make different machine and ship to dealer that will accept only one size deck. I bought a new F2690 and it has a 60" SD with mulching kit which the dealer had on hand and had to wait over a month till the machine arrived to then install deck. I believe dealer gets the machine and installs the deck. Just not seeing making different power bodies for specific deck. :2cents: when different sized decks are offered.
   / Will a 72" deck fit a ZD1211 that originally came with a 60" deck? #7
My father in-laws ZD1211 60 SD “looks” the same wheelbase as both my 72 machines.
I hadn’t physically measured them tho.
I know my front axle is 7 Wider than a 60 cut.
The rears are the same width / same transmission.
   / Will a 72" deck fit a ZD1211 that originally came with a 60" deck? #8
The ZD1211-60 and ZD1211-72 have different and unique part numbers for the main frames. That leads me to believe that 4570Man is correct, the 72” deck will not fit a ZD1211-60 chassis.
   / Will a 72" deck fit a ZD1211 that originally came with a 60" deck? #9
Dealers do not install decks on zeroturn mowers, they arrive crated with decks installed. Front deck machines are a completely different animal, there are uses for them that do not include mower decks. Additionally F-series attachments are by definition in front of both axles, not between them.
   / Will a 72" deck fit a ZD1211 that originally came with a 60" deck? #10
Wheelbase length must be a little different ?
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
Adams Conveyor (A51039)
Adams Conveyor...
2014 PETERBILT 367 (A50854)
2014 PETERBILT 367...
(2) 300 GAL WATER TANKS (A50854)
(2) 300 GAL WATER...
1996 Monon 45X96 Dry Van Trailer (A51039)
1996 Monon 45X96...
10FT. S/A Utility Trailer (A49461)
10FT. S/A Utility...
