Grading Will a 7 foot rear blade spin around on my dk45s?
   / Will a 7 foot rear blade spin around on my dk45s? #1
spanky8N
Wisconsin
Red, blue, orange, green...did I miss any?
Does anyone know if a 7 foot king kutter rear blade will be able to rotate between front and rear facing while staying connected to the three point?
Dan
   / Will a 7 foot rear blade spin around on my dk45s? #2
It should..
I can spin the 7' King Kutter (professional series) rear blade on my DK 35.
   / Will a 7 foot rear blade spin around on my dk45s? #4
Yes it should. General thoughts are 50hp per foot of cutter.
   / Will a 7 foot rear blade spin around on my dk45s? #6
I have a 7' rear blade and I can not spin it around without removing the draw bar. I have a DK-45
   / Will a 7 foot rear blade spin around on my dk45s? #7
Sorry....didn't catch the type-o till now..... /forums/images/graemlins/tongue.gif
That's 5 hp per
   / Will a 7 foot rear blade spin around on my dk45s? #8
Shouldn't any blade swivel 360 degrees? The frame would be built to extend far enough back to clear whatever size blade that it is holding. As noted before, some models may require the drawbar be removed or slid back under.
   / Will a 7 foot rear blade spin around on my dk45s? #9
</font><font color="blue" class="small">( Shouldn't any blade swivel 360 degrees? The frame would be built to extend far enough back to clear whatever size blade that it is holding. As noted before, some models may require the drawbar be removed or slid back under. )</font>
A well designed blade will spin around. The ability to spin is more dependant on the design of the blade than on the tractor brand, size or HP it is attached to.
If properly designed, the pivot point of a blade will be held roughly 1/2 of its width behind the 3 point hitch. So a 4' blade would have its pivot point at roughly 2' back, a 6' blade's pivot point would be roughly 3' back and an 8' blade would be held back roughly 4'. Most manufacturers will do this.
   / Will a 7 foot rear blade spin around on my dk45s? #10
You may have to shorten the centerlink to get it to spin around.
2019 Challenger MT738 Track Tractor (A53342)
2019 Challenger...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A53472)
2009 Ford F-650 24...
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
