wiggle, squirm and crawed on my belly like a reptile
   / wiggle, squirm and crawed on my belly like a reptile #1
mjarrels
Elite Member
Virginia
1949 farmall, 1961 Fordson Dexta, 1986 Duetz Allis, 2001 Kubota.
I just replaced the toilet flust valve in a rental house this week and it is a major pain... must be a better way. Next I need to replace the bath sink faucets and you can't even see the connections. Short of placing a service call at $65.00 an hour, is there a better way of changing this.
mark
   / wiggle, squirm and crawed on my belly like a reptile #2
With my access problem I cut through the wall so I could get to two tub fixtures back to back. I put the sheetrock back in place and hung a shelf to hide it.
   / wiggle, squirm and crawed on my belly like a reptile #3
Home Depot, Lowes, and I'm sure others sell a plastic frame and door that you can use to put over the hole you cut to access the valves. I did that on a job once when the client wanted it done right away and didn't want to mess with patching sheetrock.
Eddie
Only problem is this house is about 120 years old and toilet and sink fixtures break the rules and are in the outside wall.
mark
"we feel we are as confused as ever, but we think we are confused on a much higher level and about more important things"
   / wiggle, squirm and crawed on my belly like a reptile #5
I'm guessing the bathroom sink is mounted on top of a cabinet attached to the outside wall. Then you haven't much choice if you want to replace it. You must get up underneath inside the cabinet to reach the two hold down nuts that hold the faucet to the sink. When replacing the faucet, buy yourself a pair of flexible water hookup hoses (usually 1/2" Female x 3/8" compression x whatever length) to make things easier next time.
On the toilet flush valve you can replace the assy. with a fluidmaster unit which has a built in float and get rid of the big brass or plastic ball on a rod. Fairly easy to change.
   / wiggle, squirm and crawed on my belly like a reptile #6
You may want to invest in a basin wrench- a self adjusting pipe wrench head that swivels so it is 90 degrees to a long rod, then a handle to turn with. Allows you to get up to the fittings on the faucets. Not something you will use often, but I would highly suggest it in this case.
Oh, yea- a big bottle of asprin...or scotch...
   / wiggle, squirm and crawed on my belly like a reptile #7
That's all I use, the packaged ones. Super easy to replace.
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A55302)
2019 New Holland...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A55301)
2020 Massey...
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
