ning
Elite Member
I was tending to my birds this morning, filling up a duckling *ahem* kiddie pool for the young ducks & geese, and I noted in passing that while I had a decent (but not impressive) amount of water flowing, there wasn't much pressure. Oh well.
Luckily my next morning chore spot was letting out my grown ducks & geese, and I'm like "...... is that water I hear?" lucky for me, the problem was two trees away where a plastic drip hose connector had ruptured and was dumping water. Quick fix.
Realized, though, that a water pressure sensor could alert me to something like this, because I try to "intelligently" balance my watering so in pretty much any line there should still be enough pressure to operate drip - 20-25psi. If I had a sensor that could alert me if the pressure got below, say 10psi, I could be like "oh crap something's spilling".
I recently bought some convenient wifi connected temperature sensors that you stick in a deep freeze (guess why I suddenly bought these, and yes it had something to do with a GFCI outlet kicking the bucket). There's a ~4mm x 30mm cylinder that goes in the freezer or fridge, connected by a long thin ribbon cable, with a wifi sender at the end of that. I get an alert every time someone goes in the deep freeze! But I also get told about a minute later that temperature is good again (I can set the alert temp; I have it pretty low still because if I get an alert that it's melted that's no good right? how about "hey nobody's home but the freezer is at 10F, you've got a few hours to get home and plug it in somewhere else).
I'm hoping for something similar - the maker of my temperature units doesn't have one - for water pressure. It could be something I put into a T, or stick on a hose bib left open, or whatever. Wifi, though, is kinda key here.
Ideas?
Ideas?
