Wider wheelbase on L2800
   / Wider wheelbase on L2800 #1
Hanksride
Bronze Member
Kubota L2800
I have a 2005 L2800 with Industrial tires, (R4's I think they are called) can I widen my wheel base. It seems to me that the manual states it can only be done with the AG tires but I don't understand why.. Seems like it is a matter of unbolting the wheels and spinning the disc behind them to a wider stance and rebolting.... Will this work with my tires???
Bump, still looking for answer to this one!
   / Wider wheelbase on L2800 #3
Wow, you're a patient man to wait 2 years to bump a question.
I don't know your tractor, but if the disc can be spun around, you should still be w/i spec of your tractor's capabilities. After 2 years, I'd just go ahead and try it. The other option might be to swap the wheels from one side to the other. I've read here about 4 different settings between the cup of the disc and the position on the rim (mounting is closer to one side than the other). Whether that fits your tractor or not, I cannot say, but if you need it wider, I'd jack it up and give it a shot.
   / Wider wheelbase on L2800 #4
2 years! :eek:
Most of the R-4 rims on these smaller tractor are a one piece rim. Is yours this way? Only the AG style two piece rim and disk can be adjusted in and out. Another reason to like AG tires...
   / Wider wheelbase on L2800 #5
The dish on the R4's is already close to the inside and can not be reversed. This gives the L2800 a fairly wide stance. You should be able to get some spacers, but I believe that it is not recommended with the R4's on this tractor.
   / Wider wheelbase on L2800 #6
what tires are on it doesn't matter its what wheels are. R4 will on same wheel as ag tire will.
   / Wider wheelbase on L2800 #7
R-4s on the smaller Kubotas come with a one piece rim. Some of the larger models have the two piece rim with R-4s.
Thanks for the input, I will take a look and see if I have the one piece wheels or not. 2 years, haha yeah I was going through my old post and noticed I never got an answer to this one. Hasn't been a big deal but I recently got a backhoe attachment and noticed it making things a little more top heavy so thought I would readdress this. My B7500 had widening options with pins in the axle stubs but didn't see how this one would do it. Thanks again.
   / Wider wheelbase on L2800 #9
I have reversed the rears on my 2550 as I have the two piece rims. If your tires are loaded I recommend you have a second tractor with a loader to work the tire lest you spend the rest of your life under it. :).
   / Wider wheelbase on L2800 #10
I have a L3700 (same frame as the 2800) and the wheels are one piece. Also what kind of backhoe did you get?
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
2020 VOLVO VNL64T740 TANDEM AXLE MID ROOF (A52141)
2020 VOLVO...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2006 Cat 963C Crawler Loader (RIDE AND DRIVE) (NICE) (A50774)
2006 Cat 963C...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
