Tires Wider tires and MMM anti scalp wheel
   / Wider tires and MMM anti scalp wheel #1
cchoate
Near Buffalo, NY
Kubota GL3430 HST
Moving my rear tires to the widest position makes them rub on the anti scalp wheels of my mmm. I know this topic has been discussed before but has anyone found a solution yet?
B7500hst
60"mmm
turf tires
R-4's soon
   / Wider tires and MMM anti scalp wheel #2
This isn't a solution, it more like ignoring the problem, but here's what I tried. There's "only" one anti-scalp wheel that rubs on my B2410/60"mmm/R4 tires. You can remove it, but the mower flops around a bit. Next you can lower it as much as possible so it doesn't bump much. If you raise the MMM to its maximum height minus just a bit, it won't rub. The best thing is that when I suspend the MMM from the two front pins, the back of the mower sags enough that the anti-scalp wheel doesn't rub. Pretty much everything about the MMM set up needs a bit more work: removing it, pinning it up, and the anti-scalp wheel are not up to typical, easy to use, Kubota standards.
   / Wider tires and MMM anti scalp wheel #3
There is no real solution. You cannot put the tires out to the widest position with the MMM installed, it works fine at the more inward setting.
Yeah, I agree the MMM arrangement needs work, just for Gunfighter, I want the engine flipped around and moved back, I want the battery left forward however and I want the radiator just in front of the seating area like the BX with reverse flow. I want the fuel tank moved under the seat/fenders and I want reduced overhang on the front like the BX. I want a suspended MMM with a height control knob under the seat area. I would like the more roomy floorboard area of the BX and a slightly wider floorboard too with a handle somewhere to help off and on and I want to get rid of as much plastic as possible. I want a bigger BX--and I want a cup holder too!!!!!!!! and if it has a lawn tractor transmission I am wanting that too. Go ahead also and give me a few more horsepower. I want a clutchless arrangement for the PTO levers, PC, and more cast iron. An available intergrated Backhoe would also be nice. J
I just want my rear tires not to rub on my anti-scalp wheels.
1" Pneumatic Impact Wrench (A59076)
1" Pneumatic...
Behringer 19 high x 43 wide Metal-Cutting Bandsaw (A59213)
Behringer 19 high...
2121 (A58376)
2121 (A58376)
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A56129)
2000 GMC C7500...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
