wider front tires
   / wider front tires #1
corelokt308win
I'd like to somehow rig wider front tires on my little Iseki TL2100 four wheel drive. The tires are always getting me stuck due to the loader weight. Are there wider rims with similar diameter, or could these be widened?
   / wider front tires #2
What ever you do match the tire diameter for the use. It is very imortant to match the tires as I've seen the drive shaft spitting out within four hours of operation! That's not cheap for any one!
   / wider front tires #3
What kind of weight do you have on the rear to offset what your picking up on the front? Might just need to load your rear tires or attach an implement, or both.
   / wider front tires #4
Always ensure you have adequate inflation in those front tires...that may be your problem.
And, maybe your fronts need replacing...might not have enough tread left on them.
   / wider front tires #5
   / wider front tires #6
I widened a pair of rims, not too hard to do. I put some pics up while I doing it on another forum
See here
   / wider front tires #7
Can you repost the pics here? It wouldn't let me see them without being a member/signing in or some such message.
   / wider front tires #8
You'll have to look at the other site for the descriptions of the pictures
   / wider front tires
The tires are new, 6 ply's. The rears are loaded with calcium in tubes. The fronts are sinking into a bog area that crosses most of my land. Once you go through the top most layer, it's pure mud about 4 feet deep. Wider fronts would help float the weight of the loader.
2007 KOMATSU PC27MR-2 EXCAVATOR (A51242)
2007 KOMATSU...
2019 CATERPILLAR 315FL CR EXCAVATOR (A51242)
2019 CATERPILLAR...
UNUSED CFG Industrial MY50R Mini Excavator (A47384)
UNUSED CFG...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
2002 Chevy 3500 Dump (A47384)
2002 Chevy 3500...
