widen stance on L3400
   / widen stance on L3400 #1
Ranch120
Has anyone heard or have experience with widening out the rear wheels (extending out) on a L3400 will produce extra torque and stress on the axle and its bushings? I have steep hills and was trying to get a wider base underneath the tractor.
Thanks!
   / widen stance on L3400 #2
I would think that if you followed the reccomendations in the owners manual for changing offsets any premature axle or bearing failure would be under warranty.Ask your dealer to confirm.
   / widen stance on L3400 #3
I am not the expert, but I recall seeing here (somewhere) that only R-1 (AG) tires can be extended outward. Maybe somebody with the facts can reply.
   / widen stance on L3400 #4
I have R4's on my L3400 and the rears cannot be adjusted but the fronts can be flipped giving you 2 different widths for the front. also it puts the valve stems on the inside protecting this a bit more.
   / widen stance on L3400 #5
Hi Ranch:
I posed a similar but different question regarding widening the track width on my L4400 some time ago. Ag tires.
N80 gave me valuable advice. Do a search to find it.
Other good advice said not to widen the track any wider than the bucket is.
If you have places where maneuvering is tight, like around outbuildings or if you are working in the woodlot on narrow woods roads the 4 inches you would gain would be at some expense, perhaps at a distinct disadvantage.
I don't think there is detrimental stress introduced when the wheels are widened using factory rims. These things have been engineered on tractors for 75 years, and sized to work.
simonmeridew
   / widen stance on L3400 #6
The manual for the L4400 has a chart showing all the available adjustments for width, I suspect the 3400 manual does too. As mentioned, I think this only works with r1s.
   / widen stance on L3400 #7
I have L3400 with Kubota loader. My book says "do not reverse front wheels to widen track" Says that it puts too much stress on the front axle. I widened my rear wheels as far as possible to make it more stable on hillsides.
UNUSED HURRICANE 5' X 10' CONTAINER (A51248)
UNUSED HURRICANE...
REMLINGER 2300 LOT NUMBER 59 (A53084)
REMLINGER 2300 LOT...
MONOSEM NG-3 LOT NUMBER 273 (A53084)
MONOSEM NG-3 LOT...
CASE 580 SUPER N BACKHOE (A51246)
CASE 580 SUPER N...
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
