wi fi in shop
   / wi fi in shop #11
300ft is the limit for Cat5 & Cat6. Plus, an electrical surge (lightning strike) will follow the copper & fry anything connected to it. Wireless bridges can get tricky sometimes.
If possible, run fiber in electrical conduit underground. (Fiber will melt if hit by lightning.) Can't have a better connection than that.
I ran fiber between our house and shop, but for a very good reason. The shop was built first and all utilities are terminated there, and then go to the house, where the primary need is. I was also thinking about security cameras, too, so bandwidth could be large. It is over 300'. I had a cat5 running the link for a while, but I could tell it was pushing it (slower than it should have been). I had the cable co pull and connect the fiber as it requires special (and expensive) tools and expertise. I think it ran $700 or so for fiber, pulling it, and terminating the connections. Money well spent. Conduit was ran by me during construction with pull cords in it. Much faster now. Unless you have a BIL who installs fiber for a living, i would not think it would be worth it for the OP's needs.
   / wi fi in shop #12
One can buy preterminated fiber cables of almost any length. A 328 footer may cost $140. But you need fiber transceivers/routers/switches/network cards.
The "expertise" required is just slightly different than running preterminated CAT6.
When I was teaching troops in the Army part of the training course required hooking up separate shelters with fiber cable. Very simple if you don't have to make the ends. Just handle with care, they break relatively easily.
   / wi fi in shop #13
I would agree, if you had open access and weren't pulling it through pipe. Ain't no way that is going to survive a 300' pull through conduit. They had 2 guys pulling with all their might on that thing and one feeding from the other end(also pulled cat5 and coax at the same time in 2" conduit). You could try feeding it as you laid the conduit, but even that would be iffy for that distance. What you show is basically a long patch cable, which I used on both ends of my run from the pulled cable termination to the specially equipped port on the switch (~3' patch cable). I also doubt it is rated for wet locations, which an underground conduit most definitely is. In my case they used the same direct burial fiber cable they use to run down the roads and to each house in the town. And about 4 gal of a 5gal pail of special fiber pull lube.... This was not trivial to do, which is why I hired it out. And I am not one to hire out jobs much.
   / wi fi in shop #14
Yes, you need to set two of them up as a wireless bridge. One will be on the house and the second one on the shop. Both are hardwired to the inside with CAT5 cable. You can add an Ethernet switch to the shop if you need more than one device.
Since the OP can get signal outside his shop, he does not need two to set up a bridge. He can install the one at the shop and it will function as a antenna. That is what worked for me.
You can also get an one that will focus as a wireless access point (a remote router).
   / wi fi in shop #15
Is it possible to use your cell phone as a hot spot? I do that in my shop (150' from the house) and get better WIFI than in the house. The only thing I run into is it only seems to work with a windows operating system as my phone, laptop and tablet are all windows OS. I have this Ipad that Im on now because my wife is a die hard apple fan Christmas gift. I cant seem to get it to connect out there but it is probably operator error
   / wi fi in shop #16
Cell phone hot spot is great. I often "work from home" and stay in the shop.
   / wi fi in shop #18
   / wi fi in shop #19
My shop is about 1000 ft from our house where the Wi-Fi resides. Will I need two of these units? One at house and second one at shop?
Shop is metal building and metal roof, will that be an issue?
Thanks!
Yes, I would use two, one on the outside of the house (or in a window) and one on the outside of the shop. I would however use the Ubiquity Nanostations I linked to earlier as they are cheaper ($45ish vs $80ish) and I would get the Ubiquiti AIRGATEWAY access point to sit on the power brick inside the shop and provide wifi out there.
I have had two of the Nanostations running on a 550' link for the past 5 years with no hiccups and almost full bars, 1000' shouldn't be a problem (as long as you dont have too many trees in the way)
Aaron Z
   / wi fi in shop #20
Aaron Z
Thanks Aaron. Are these devices line of sight?
HEAVY DUTY 7' X 13' X 3.5' WAREHOUSE STORAGE SHELF (A54757)
HEAVY DUTY 7' X...
10' Fork Extensions (A53316)
10' Fork...
2025 JMR Tree Boom Skid Steer Attachment (A53421)
2025 JMR Tree Boom...
2012 Chevrolet Cruze Sedan (A55758)
2012 Chevrolet...
2012 Club Car Precedent Electric Golf Cart (A53424)
2012 Club Car...
