Why the PT Reverse Whiplash
   / Why the PT Reverse Whiplash #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I read solutions (use your toe, be gentle, put a bolt on the treadle) but why does the reverse give you whiplash and not forward. The circuit looks to be the same...
Carl
   / Why the PT Reverse Whiplash #2
Carl
On my 425, the treadle arm is shorter on the left than on the right, as I recall, i.e. the "levers" are different lengths from the fulcrum (the pivot). The same amount of downward movement, let's say 1/2", will open the valve farther in reverse than in forward, providing more hydraulic flow in reverse than forward....
Flow or volume = speed, so it's more likely to jerk more in reverse than forward because the controls are more sensitive in that direction...
Could be part of the answer...
   / Why the PT Reverse Whiplash #3
Kent is right. I have the older 425 but I went to Taz and drove the newer model. I think that is part of the problem. The other part is when you start going in reverse it slightly throws your weight forward, which causes you to step on the treddle a little more which makes the problem worse. I've run alot of equipment in my life and when you are on a new piece of Equipment, you think you are not going to let it happen, but no matter how hard you try it does. Once your body gets used to the forces it will compensate.
   / Why the PT Reverse Whiplash #4
Well, also when going forward you have a seatback to compensate the force of you going backwards.
When you go backwards, nothing to lean into.
CFG Industrial QK20R (A56469)
CFG Industrial...
UNUSED FUTURE FT-ZP20 20' X 30' GARAGE CARPORT (A57193)
UNUSED FUTURE...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A55973)
2015 SkyJack SJ86T...
2014 John Deere 1770NT PLanter (A53485)
2014 John Deere...
2014 John Deere 204K Wheel Loader (A53485)
2014 John Deere...
TRUCK TOOL BOX .COM (A57192)
TRUCK TOOL BOX...
