Why so much positive camber ?
   / Why so much positive camber ? #1
Arky217
Hartford, AR
Kubota L4200
I have a Kubota L4200; from the first day I got it, I've wondered why it has so much positive camber on the front wheels. (I tend to notice these things since I was a front end mechanic in what seems like was a previous life).
As measured from the middle of the tire's sidewall top to bottom, it has 1.125" positive camber on each side. That's a lot.
I haven't looked any other tractors to compare it to, but I wonder if all tractors or all Kubota tractors are like that. Maybe it's a 4wd thing.
Anyone notice that on your tractor, and/or have any idea why they're made like that ?
   / Why so much positive camber ? #2
Found this from Wikipedia on Camber angle.
"Off-road vehicles such as agricultural tractors generally use positive camber. In such vehicles, the positive camber angle helps to achieve a lower steering effort"
David Kb7uns
   / Why so much positive camber ? #3
David Kb7uns
That's what I've understood as well. I see it on alot of tractors. Everyting I've ever had leaves a trail in the gravel from the front tires, including, tractors, quads and utility vehicles. It can he hard on tires though.
   / Why so much positive camber ? #4
My guess would be that it has to do with reducing the strain on the wheel/axle bearings.
With no or negative camber, the tire contact patch would be further away from the bearing therefore creating more leverage/load.
i can see how important it would be, especially with a fully loaded FEL
   / Why so much positive camber ? #5
Another thought I have heard expressed is that under load, the axle tends to straighten out slightly so the tire ground contact is improved.
Sounds like a bit of stretch to me - no pun intended.
   / Why so much positive camber ? #6
Positive camber helps with turning.:)
   / Why so much positive camber ? #7
I don't believe that the camber is adjustable on the vintage Yanmar 2wd or 4wd front axle.
The toe-in is adjustable in the typical fashion via a threaded collar on the tie rod.
Adjustment is 1/8 to 3/8" IN. Most everyone sets it at a quarter inch toe-in.
rScotty
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
UNUSED INDUSTRIAS AMERICA 180 HYD SCRAPE BLADE (A51243)
UNUSED INDUSTRIAS...
2005 KOMATSU PC400LC-7L EXCAVATOR (A51242)
2005 KOMATSU...
HYSTER 60FT WAREHOUSE FORKLIFT (A51242)
HYSTER 60FT...
UNUSED FUTURE LASER LEVEL W/ TRIPOD (A51243)
UNUSED FUTURE...
Skidloader Forks (A50774)
Skidloader Forks...
