Why no front wheel drive trucks?
   / Why no front wheel drive trucks? #21
I think the biggest practical hurdle to FWD trucks is that they're not suited to heavier duty applications, and when a 1/4 ton or 1/2 ton design is scaled up to a 3/4 -1 ton chassis, there's just too much to redesign. Not enough shared parts to make it cost effective.
Also wonder if there is an inherent weakness in the traditional FWD platform that can't be adapted to heavier loads or towing.
Does RWD have an extra benefit towing? (besides weight transfer from the trailer to rear axle). Easier to "push" a load than "pull" it?
   / Why no front wheel drive trucks? #22
Think about stopping on a hill with a trailer hooked up to a truck going up hill. You have a trailer with a maximum load for your truck. The light turns green and you hit the gas. Think about how much weight is on and gets transferred to the rear of the truck. Front wheel drive would just spin the tires if it was wet out.
   / Why no front wheel drive trucks? #23
True, but a proper WD hitch would solve a lot of that
   / Why no front wheel drive trucks? #24
Volkswagen made one for a while. Got 45 mpg too. Don't see that anymore.
Yes. I remember those little suckers. I was shocked to see how much they are still worth.
   / Why no front wheel drive trucks? #25
Front wheel drive is generally used in unibody construction and not body on ladder frame.
   / Why no front wheel drive trucks? #26
Go to a boat launch and watch people try to pull a boat out with a FWD minivan..That would take care of any interest in FWD pickups.
The RAM Promaster van - which is actually a version of the FIAT Ducato made in Mexico - is front wheel drive. They've sold hundreds of thousands of them all over Europe. It is kind of a hybrid, with a ladder frame behind a unibody cab. The load floor is low and they have a lot of room. But as mentioned trucks of a certain size nnneed ladder frames for rigidity.
If the RAM Promaster, or Ford Transit, could tow my tractor, it would absolutely be my next vehicle.
   / Why no front wheel drive trucks? #28
Pierce Fire Apparatus made a rear engine front wheel drive fire truck for a few years in the early 1990's as a firefighter that was unfortunate enough to have been assigned to drive one on our department I can state with for certain there was no traction on snow, torque steer was crazy and you really don't want a jake brake on anything with front wheel drive. Might have been great in the southern states but not worth a dam at -25 degree temperatures or 10 inches of snow. Having said that I will also vouch that Pierce made great rear wheel drive fire trucks before and since this unfortunate experiment.
   / Why no front wheel drive trucks? #29
Look no farther than the 1985 and up Cadillacs (specifically, the Cadillac de Ville series - Wikipedia, the free encyclopedia ). They were FWD with a transverse mounted 4.1L V8.
Aaron Z
Yeah, those cars were built at the Lake Orion Assembly plant. The joke was that they performed a test on cars coming off the line, they opened the hood, poured 5 gallons of water in the engine compartment. If any water hit the floor, we were missing parts.....
Remember, it was a joke.
   / Why no front wheel drive trucks? #30
My grandma has one of these (a '93 Sedan DeVille), its pretty tight under the hood. She likes it and she and Grandpa spent a lot of time driving it around.
Aaron Z
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2007 FORD F-450 SUPER DUTY (A52472)
2007 FORD F-450...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
377811 (A48836)
377811 (A48836)
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
