Why no front wheel drive trucks?
   / Why no front wheel drive trucks? #11
I would like to see a big old V8 turned side ways. Sure wouldn't like to have one. Cost you $5000.00 to change the spark plugs. I like the trucks the way they use to be.(simple)
   / Why no front wheel drive trucks? #12
There were some front wheel drive V8 full-sized cars made. But the engine was not sideways.
Bruce
   / Why no front wheel drive trucks? #14
The RAM Promaster van - which is actually a version of the FIAT Ducato made in Mexico - is front wheel drive. They've sold hundreds of thousands of them all over Europe. It is kind of a hybrid, with a ladder frame behind a unibody cab. The load floor is low and they have a lot of room. But as mentioned trucks of a certain size nnneed ladder frames for rigidity.
If you've ever tried to tow anything with a FWD vehicle you'll know why interest is limited. I towed a 3,000+ lb sailboat trailer with a Dodge Intrepid a few times. Even though the Intrepid had plenty of power, a long wheelbase, etc, it was pretty nerve-wracking over bumps and around corners.
   / Why no front wheel drive trucks? #15
I think the Honda Ridgeline is front wheel drive. Not my idea of a truck though.
   / Why no front wheel drive trucks? #16
   / Why no front wheel drive trucks? #17
Long time ago saw a picture of a stock trailer that had been attached to the front half of a 4 wheel drive pickup, making it a front wheel drive. Made it more maneuverable and easy to load, but seems it would be hard on front drive system.
   / Why no front wheel drive trucks? #18
Bruce
The Toronado/Eldorado platform would be perfect for a truck. Lots of HP and torque but it takes a really long hood to pack it under. 7393199336_a4dd7b0eba_z.jpg
   / Why no front wheel drive trucks? #20
What everyone said already.
Point is, front wheel drive trucks would be viable if you placed the rear axle at the very end of the truck, rather than mounted halfway back. That way the load would be more (but not totally) evenly distributed over the front and back axles.
Personally, I'd like to see Toyota slap their Prius hybrid drive system under their Tacoma 1/4 ton pickup line, if only as an experiment. Electric driven wheels have greater torque than gasoline engine driven, their system is all wheel drive, and cruise control actually works going downhill. What it doesn't have is massive acceleration, so scooting out into the traffic flow can be rough when hauling a load; but then that's a problem even with gasoline rear wheel drive trucks too.
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2011 TROXELL 130BBL (A52472)
2011 TROXELL...
Sunflower 1435-30 Cushion Flex Disc (A52349)
Sunflower 1435-30...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
