deezler
Elite Member
- Joined
- Jan 30, 2012
- Messages
- 3,859
- Location
- Southeast MI
- Tractor
- Cub Cadet 7305, Kioti CK3510seh TLB
Variable timing is the bee's knees, man. Enables much nicer and more efficient combustion across a wide array of load and speed conditions. Like GM does with the small blocks. Proven tech.Why pushrod with variable cam timing, and sequential turbos without crazy boost, and no complex variable compression ratio ?
I mean, if you want an efficient low speed engine, pushrods will do fine. But why add variable valve timing (that enables a work truck engine characteristic at low rpm, and racing engine characteristic at high rpm) to such engine ? Or add a 2nd turbo, which you only need to spool up the first turbo when its very oversized in order to secure high rpm peak horsepower ?
The turbo setup is debatable, agreed. But pairing a small turbo with a large one means you can get excellent low end spool and barely notice any turbo lag (IE very quick to making 4-6 psi) and still have a huge surge of high rpm power. I want to have and eat the cake. Just dreaming, though.
Variable compression ratio typically means and ENTIRE extra spinning shaft and an extra connecting rod (with two bearings each) for each cylinder, plus multiple actuators and sensors with a complex control strategy. It might work fine. Or might be a disaster. Nissan was pretty proud of their setup for the Inifiti motors, but it maybe added 1mpg for an expensive engine and vehicle in a segment where nobody even cared.
