why does this engine have more power when reversed
   / why does this engine have more power when reversed #11
As far as I know, Mules do not have different ratios for forward/reverse. They are powered by a 4 cycle engine through a CVT system with simple forward/reverse gear selector
   / why does this engine have more power when reversed #12
For what it is worth, some older gas golf carts run the engine backwards for reverse. When you stop the motor stops. when you push the gas pedal the motor starts back up.
I wonder if an older kw mule is the same way.
Sent from my iPhone using TractorByNet
You might have some luck with checking on a golf cart form (buggies gone wild) they have info on those older motors. Might have to do w ignition timing or compresson.
Good luck.
   / why does this engine have more power when reversed #13
Not sure this is a factor or not but when I am going backwards at 20 MPH it seems faster than 60 MPH when going forward. As I understand it only a 2 stroke engine can run in either direction and the fuel and exhaust be correct. Did it once with a model plane but it would not take off backwards.
   / why does this engine have more power when reversed #14
Very easy to get a 2 stroke to run backwards. Ski-doo has been doing that with their snowmobiles for 10 years, or more.
   / why does this engine have more power when reversed #15
Yep, older golf carts were 2 stroke. They would couple a generator to the motor and use it as a starter. Flip the switch one way it runs forward the other and it runs backwards.
2009 PETERBILT 340 FLATTOP SLEEPER (A58214)
2009 PETERBILT 340...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
2006 Ford F-750 Hazardous Material Truck (A56858)
2006 Ford F-750...
GRILL GUARD FOR JOHN DEERE 5000 SERIES TRACTOR (A52708)
GRILL GUARD FOR...
