Why do my Kohler engines backfire when shut off?
   / Why do my Kohler engines backfire when shut off? #11
<font color="blue">If I run them at higher RPM's (mowing) but don't let it idle for a few minutes before shutting them off, they let off one heck of a backfire. </font>
Hey bczoom,
Explosion in the exhaust is a result of unspent fuel, hitting the hot exhaust.
It may be a result of the carburetor being set too rich. Or a dirty air filter. I would pull the plugs on a cold engine and inspect the Sparkplug insulator's color. Perfect color is slightly tan. Too rich and the ceramic insulator will be dark. If so, make sure that your air filter is clean and/or adjust your Fuel/Air Mixture.
On the bigger engines, it may also have something to do with the Exhaust Emission System as well. On some Motorcycle Engines, there is a fresh air inlet valve that leads into the exhaust chamber to fool the EPA EXPERTS, into thinking that the engine is burning cleaner, but in actualality, it is just diluting the unspent gas with more air. /forums/images/graemlins/smile.gif When that air inlet valve leaks a little bit, upon shutdown, it will provide fresh oxygen to a little bit of unspent exhaust gase and cause an explosion as well. On my Motorcycle, I stuffed a bearing up into the hose just prior to the air inlet valve going into the exhaust side of the head. It took me a long time to figure that one out. /forums/images/graemlins/smile.gif
At any rate, an explosion in the exhaust system is not helpful to any engine and a remedy should be found, before noticeable engine damage results.
Have a nice day,
Joe/forums/images/graemlins/cool.gif
   / Why do my Kohler engines backfire when shut off? #12
What does the manual say about this? I remember in my Craftsman tractor with a Kohler it says you need to idle for 30 seconds before shutdown. I'd re-read the manual first and go from there.
</font><font color="blue" class="small">( What does the manual say about this? )</font>
HUH? Read a manual? /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
Other engines I have that are the same size (18-25 hp B&S or other) in things like generators do the shut down from full throttle and don't have the problem. I'll try it with the Kohler engines but I don't think it works on the ZTR as one of the main reasons I shut down from full speed is if one of my kids is approaching or calling me.
I'll read the manual but the fuel mix in muffler sounds right and will let idle for awhile.
Brian
   / Why do my Kohler engines backfire when shut off? #14
hey Brian: with my 18 hp Briggs, if i don't throttle down for a second or 2 , it will do the same thing.
   / Why do my Kohler engines backfire when shut off? #15
I also have a backfiring kohler on my ZTR Grasshooper (which only happens on shutdown). This has been going on since the unit was new so I contacted Kohler. The represensitive said when turning off the engine turn the rpms up (vs idle) and this seem to solve my problem.
I have a 25HP Kohler in a Scotts by John Deere. I purchased new in 2000. The serv, manual tells you to idle down before shutdown. It always backfired and several times wiped out the head gaskets. After checking several web sites, suggesting to shutdown at full throtle, which I did , it hasn't backfired yet. I was told that the electric fuel pump will continue to pump fuel into the system at full capacity when shut down quickly at low RPM's. I'm on my third set of head gaskets and when they blow you know it by the smoke filling up the neighborhood. I'll keep my fingers crossed.
   / Why do my Kohler engines backfire when shut off? #16
i agree. my Huskvarna (sp?) riding mower will backfire if i idle it down prior to shut off. but wont do it if shut down at full throttle
   / Why do my Kohler engines backfire when shut off? #17
Use high octane fuel and it will not backfire. The raw fuel is getting lit off by the hot muffler, and this is why you idle it down after use to give the muffler time to cool off. I can also see that setting the throttle to full will lower the vacuum signal to the carb and prevent it from drawing in more raw fuel after the ignition has been cut. I have never tried that though but it makes sense.
I will get the occasional backfire in my briggs twin if I don't idle it down for 30 seconds or so.
   / Why do my Kohler engines backfire when shut off? #18
How the Kohler carb works at shutdown. the fuel solenoid on the Kohler shuts off the main jet of the carb but not the low speed idle circuit. when at idle the engine can pull fuel from the low speed jet when shut off causing the afterfire. At the high speed position the governor opens the throttle when shut off because the engine is slowing down and tries to get fuel through the high speed jet which is blocked by the solenoid therefore no fuel can get through to the muffler to cause the afterfire.
Illinois Engine
Warranty Kohler dealer
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
1990 KENWORTH T800 FUEL AND LUBE TRUCK(INOPERABLE) (A50854)
1990 KENWORTH T800...
Ranch Hand Pickup Truck Grill Guard (A49461)
Ranch Hand Pickup...
2013 FORD F750 26FT BOX TRUCK (A51219)
2013 FORD F750...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A51219)
2016 INTERNATIONAL...
