Why did my oil filter blow off on my Massey Ferguson 1010.
   / Why did my oil filter blow off on my Massey Ferguson 1010. #1
Chris W
Albany, mn
massey ferguson 1010
I was using my Massey when I stopped to look at something and brought it down to an idle and the oil filter came off. I backtracted where I was driving and did not find a oil trail. The filter will not rethread back on tight, but the threads on the block look good. could something be plugged? I'm stumped!
   / Why did my oil filter blow off on my Massey Ferguson 1010. #2
You didn't tighten it down and got lucky. There is a bypass in both the pump and filter if flow is blocked in the filter or engine.
That's my best guess!
Ford Super Duty Pickup Truck Bed (A49461)
Ford Super Duty...
2020 John Deere 6110M 110HP 4WD Agricultural Tractor (A49461)
2020 John Deere...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2015 FORD F-650 (A50854)
2015 FORD F-650...
