Why are transfer tanks not listed for gasoline?
   / Why are transfer tanks not listed for gasoline? #1
Ryanstones
NW Ark
I see on almost all truck mounted fuel transfer tanks exclusions for use with gasoline. Does anyone know specifically why that is so, or is this lawyer speak?
Thanks in advance.
   / Why are transfer tanks not listed for gasoline? #2
Don't know the official answer, but I would guess that because of gasoline volatility, safety and emission laws would require a pressure relief and vapor recovery system, which would be somewhat expensive and complicated.
   / Why are transfer tanks not listed for gasoline? #3
Safety and liabililty, would be my assumption. Static electricity plays an important role here.
Good thoughts Fellas, thank You for your quick replies!
   / Why are transfer tanks not listed for gasoline? #5
Thanks in advance.
Also because you need a CDL to carrry gasoline in a container larger than 8 gallons.
Thanks Duff.
I really like the quote in your sig. So true.
   / Why are transfer tanks not listed for gasoline? #7
Cite a source.
Last i checked everyone has a container larger than 8 gallons in every vehicle we drive that carries gas.
   / Why are transfer tanks not listed for gasoline? #8
Cite a source.
Gasoline
Gas may be carried under the Hazardous Materials -
Materials of Trade Exception (49 CFR 173.6) in
quantities not greater than 8 gallons per container with
the total weight of all hazardous materials not exceeding
440 pounds (at a weight of 35 lbs per 5 gallon
container). Any quantity of gasoline greater than 8
gallons per container must comply fully with
hazmat regulations.
http://telsafe.org/Documents/NTSPGas-DieselFuelTransportation.pdf
I don't. I drive diesels. :laughing:
The vehicles fuel tank doesn't count.
   / Why are transfer tanks not listed for gasoline? #9
and continue with your quote
Gasoline carried in quantities per
container greater than 8 gallons per container must
comply with the following:
1. The package/container must be marked on one side
as follows:
Gasoline
UN1203
2. The package/container must be
labeled with a class 3,
flammable liquid label.
3. Shipping Papers must be carried
along with an MSDS sheet for gasoline.
Gasoline carried in excess of 119 gallons must
comply with items 1-3 above as well as the following:
1. The driver must obtain a Commercial Drivers
License with a hazardous materials endorsement.
2. The vehicle must be placarded with the appropriate
placard.
which is to say over 8 gal has to be labled properly but nothing addtional.
it is not untill 119 gal! that a CDL is required and must be hazmat placard.
   / Why are transfer tanks not listed for gasoline? #10
so to answer the OP....
Based on the above, if you buy a standard transfer tank of less than 119 gal and affix the proper labels to the side
you should be good to go.
2017 Mack GU713 Granite Tri-Axle Dump Truck (A52377)
2017 Mack GU713...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2008 AAR MOBILITY SYSTEMS REFRIGERATOR CONTAINER (A54607)
2008 AAR MOBILITY...
2021 BOBCAT T870 SKID STEER (A52705)
2021 BOBCAT T870...
2013 Infiniti M37 Sedan (A53424)
2013 Infiniti M37...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
