Why are deck over trailers (usually) only rated for 10k?
   / Why are deck over trailers (usually) only rated for 10k? #1
Illini22
Northern Illinois
2013 Kioti dk40 hst, wright stander zero turn
Most, if not every deck over I see are only rated for 10k pounds?
   / Why are deck over trailers (usually) only rated for 10k? #2
I sell 3 different brands of trailers (Felling, Interstate, Towmaster), all of them have deckovers rated to 70K lbs. What weight are you trying to haul?
   / Why are deck over trailers (usually) only rated for 10k? #3
Is there a legal reason? For example, I see many trailers rated at 2990, because 3000+ requires brakes.
Bruce
   / Why are deck over trailers (usually) only rated for 10k? #4
I think it has to do with what can be hauled behind a pickup without requiring a medical card. IIRC its a 10k or under trailer OR a GCWR of less than 17klbs. It has nothing to do with what is able to be produced.
   / Why are deck over trailers (usually) only rated for 10k? #5
I would have said that it was the other way around. I have rarely seen a deck between over 14K but deck overs go way up in weight ratings just as Showroom shine stated. Look at every trailer being towed with an excavator behind a dump truck. They are rated at at least 24-35 and all are deck overs.
   / Why are deck over trailers (usually) only rated for 10k? #6
Up here, you need a Class A CDL for 10,000+ lbs.
A lot of light trailers are marketed with that in mind. As stated, deckovers should be available near you well in excess of 10k#.
Rgds, D.
   / Why are deck over trailers (usually) only rated for 10k? #7
My brother has a 40k deck over for his excavating business. You are right about the 10 k trailers-it keeps you out of CDL territory. I had a single axle trailer that was rated for 2990lbs, although it had a 3500 lb axle- anything over 3 k requires brakes here in NY.
Will
   / Why are deck over trailers (usually) only rated for 10k? #8
My Belshe deck over has a GVWR of 21k and is a pintle hitch.
I assume you are looking at bumper pull? That probably has a lot to with it. Unless you get into the pintle hitch style for pulling behind something like a dump truck going over 10k on a bumper pull type trailer isn't a really good idea.
   / Why are deck over trailers (usually) only rated for 10k? #9
Why does the connection matter? The equipment trailers I use for work can carry up to 15K, one is a 2" ball hitch, one is a pintle. Dont think one being a pintle automatically makes it heavier duty.
   / Why are deck over trailers (usually) only rated for 10k? #10
I highly doubt that 2" ball coupler (or the ball itself) is rated anywhere near 15K#. If either component is rated for less, hauling more presents a liability problem in the event of failure.
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2022 New Holland Powerstar 110 Tractor with Loader (A51573)
2022 New Holland...
2006 Hino 268 Truck, VIN # 5PVNJ81T962S11110 (A51572)
2006 Hino 268...
JOHN DEERE 7R210 LOT NUMBER 49 (A53084)
JOHN DEERE 7R210...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
