Who's running or has run a Tigercat M760 ?
   / Who's running or has run a Tigercat M760 ? #1
WestshoreConstruction
The Great white North
I have a question for you if you have, did the machine seem to hang up on the relief valve or seem slow to recover ? I have the rock drum on mine and for some reason it seems to hit the relief easy and it seems slow for the attachment pump to recover.. I bumped the relief to 5300 and its a little better but still seems to hang a little too long. Oh right, FAE 500U-250 rock drum.
   / Who's running or has run a Tigercat M760 ? #2
I have never run an FAE but you need to check your voicemail!
   / Who's running or has run a Tigercat M760 ? #4
check fuel filter and acuator on turbo 10 pounds of pressure should open it .air pressure
   / Who's running or has run a Tigercat M760 ? #7
check accumalater if it loses nitrogen it will not recover fast
It's fine, apparently according to TC it's only there to absorb spikes in the hydraulic system.
   / Who's running or has run a Tigercat M760 ? #9
WELL KEEP CHECKIN PRESSURES.YOU WILL FIGURE IT OUT
   / Who's running or has run a Tigercat M760 ? #10
look for the spike relief on the head, it should be at 800psi over the multi-function valve on you carrier. if this check valve is lower or defect the close loop is by-passing until your pressure is under the setting of that valve. good luck.
2015 KUBOTA M9960 LOT IDENTIFIER 121 (A53084)
2015 KUBOTA M9960...
UNUSED X-STAR 20' X 101" LOADING RAMP (A51247)
UNUSED X-STAR 20'...
Athey 7-12D Force Feed Loader (A52384)
Athey 7-12D Force...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A51248)
UNUSED WOLVERINE...
