Who's running or has run a Tigercat M760 ?
   / Who's running or has run a Tigercat M760 ? #1
WestshoreConstruction
The Great white North
I have a question for you if you have, did the machine seem to hang up on the relief valve or seem slow to recover ? I have the rock drum on mine and for some reason it seems to hit the relief easy and it seems slow for the attachment pump to recover.. I bumped the relief to 5300 and its a little better but still seems to hang a little too long. Oh right, FAE 500U-250 rock drum.
   / Who's running or has run a Tigercat M760 ? #2
I have never run an FAE but you need to check your voicemail!
   / Who's running or has run a Tigercat M760 ? #4
check fuel filter and acuator on turbo 10 pounds of pressure should open it .air pressure
   / Who's running or has run a Tigercat M760 ? #7
check accumalater if it loses nitrogen it will not recover fast
It's fine, apparently according to TC it's only there to absorb spikes in the hydraulic system.
   / Who's running or has run a Tigercat M760 ? #9
WELL KEEP CHECKIN PRESSURES.YOU WILL FIGURE IT OUT
   / Who's running or has run a Tigercat M760 ? #10
look for the spike relief on the head, it should be at 800psi over the multi-function valve on you carrier. if this check valve is lower or defect the close loop is by-passing until your pressure is under the setting of that valve. good luck.
2020 JOHN DEERE 8370R LOT IDENTIFIER 180 (A53084)
2020 JOHN DEERE...
UNUSED FUTURE FR70 69" LEVELER (A51248)
UNUSED FUTURE FR70...
2005 FL70 Freightliner, CAT C 7 Engine (A52384)
2005 FL70...
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
UNUSED CFG QUICK ATTACH HYD HAMMER (A51248)
UNUSED CFG QUICK...
2013 Caterpillar 950K Articulated Wheel Loader (A51691)
2013 Caterpillar...
