Thanks, fellows. Just one of those things we've worked out around here. I like doing our own butchering because
A: I KNOW I got my meat (you never know with processors if you got yours, or ALL of yours. My guess is those guys don't buy any meant.
B: We take our time, cut it the way we want it cut
C: I know it's cleaner, because my wife is a cleaning nut...."wash your hands, wipe that with bleach, change your apron, etc"..trust me....USDA ain't got NOTHING on her but a stamp !
D: Animals here suffer zero stress. You load them up, take to a processor, run then thru their chute with electric prods, they smell the whole place, and you KNOW they are pumped full of adrenaline by the time they hit the slaughter house floor. Here, one quick head POP, and stick to bleed out, and they never know pain.
Do you only use the window unit to keep it cool? How cold can you keep it and how long do you store stuff in there?
Eddie,
I use a "Coolbot" controller on a 10,000BTU window AC. The controller allows me to take the room down to 34-35 degrees and hold it there as long as I want. As to length of time, pigs we chill over night, and usually cut up the next day, or day after that at the latest. A beef, I'll hang 10 days to 2 weeks to age it some. I don't run the cooler most of the time, just when we have something to butcher. Otherwise, I roll the bandsaw, and other stuff in it to store out of the way.
The Coolbot over rides the normal AC controls. Most window AC units will shut down around low-mid 60's, since they assume you don't want to cool a room below that. This controller you set the room temp you want (33 on the lowest setting), and it has a little heater deal that applies heat to the window AC sensor so it never 'senses' it's down to 65, and it just keeps running. I can take the 6x6 cooler room down to mid 30's in 4-5 hours.
Go to the Coolbot website.....he has LOADS of good info, including cooler design, which AC to buy, and which to avoid, and so on.....worth the tour. The Coolbot was designed for small produce producers, to keep their stuff cold before going to market....but they work just fine for a meat cooler as well.
Build Your Own Walk-In Cooler With Coolbot
