Who's Built Their Own Pole Barn
   / Who's Built Their Own Pole Barn #1
Rumbles1960
Retiring to Bancroft, Ont
Massey Ferguson 281, GC 1710
Hi All, Just new here but been lurking around a while. Retirement is just around the corner and I have bought some property in Bancroft, Ont. I plan on retiring to. First thing I will need is a pole barn style garage/shop. Saving money is important and I'm pretty handy so I'm thinking of building it myself or at least some of it. Can anyone advise on wether this is feasable or what part of the construction would or would not be? Thanks
   / Who's Built Their Own Pole Barn #2
If you have and FEL you should be able to set the rafters on top of the poles with it. Do a search and you will find some ingenious devices folks have made for just these activities that allow them to reach up to 25 feet with the FEL by attaching a boom pole to the FEL bucket. You would need some real finesse with the hydraulic to smoothly pick up the pre-assembled rafter spans, but they seemed to do it OK>
Since you are so far north, I would think that your biggest hurdle would be digging the holes for your poles and getting them down below the frost line. This might require some special equipment to dig and set them and get them plumb and in the correct location. They would need to be pretty well dead nuts right on coordinates unless you planned to stick build each and every rafter to fit. Once the poles are set, the rest is a cake walk. There is also a lengthy discussion here from someone who built their pole barn and listed all the issues that he had. Be worth your time to search it out under the Built it Yourself forum.
   / Who's Built Their Own Pole Barn #3
I built my 24 x 40 completely by myself with the exception of having my 63 year old neighbor help hold the post hole auger. Took about two months of free time from post holes to the last outlet cover plate. I built my own trusses from plans I found on the internet and hung them by just carrying one end up to the top of the ten foot wall,then carrying up the other end. Rolled them upright with a 12 foot 2 x 4 and leaned them against the last one until I could put it in place.
   / Who's Built Their Own Pole Barn #5
You can do the work yourself pretty easily. A post hole digger with 12" (15" would be better) auger is very helpful. It's not too bad to get the posts into the holes by hand. It's a 2 guy job or a one large guy job for sure! The rafters can also be a one man job, but 2 or 3 makes it much easier. You can do a lot with rope and blocking if you are inventive and alone.
Everything else is pretty straight forward. Well worth the 3-5000 labor cost savings.
jb
   / Who's Built Their Own Pole Barn #6
My area was just north of the southern boundary of the ice sheet and is consequently heavy in buried small boulders. So it's not possible to dig a nice vertical hole without hitting rocks and having to widen the hole. The technique that they use here is to dig the hole as best they can and then set the poles in concrete.
   / Who's Built Their Own Pole Barn #7
As a side note... I was told by the Building Dept that they prefer the posts to be set in tamped gravel instead of concrete since it will drain away from the posts.
   / Who's Built Their Own Pole Barn #8
If there's any possible way to have this built by a professional, then that is absolutely the best way. I tried building my barn myself, but it turnrd out that it was just too much. Now understand that I have several years of professional carpentry in my history, so I know what I'm doing. What became the show stopper was the fact that it was going to take me so many weekends that I wouldn't have finished for a year. I finally admitted it was too much for one man and paid to have it done. Slab and block foundation, T-111 walls, three really large doors, electrical, roofing, and the road to get to it.
   / Who's Built Their Own Pole Barn #9
   / Who's Built Their Own Pole Barn #10
Haven't built a pole barn, but I did build this pole frame shed (20x28 ft, 10ft roof dropping to 9 ft) last year. If I can build something like this, anyone can. It's not difficult and I did it myself, completely.
Used my Mahindra 5525 with FEL to lift 16 ft 2x12s into place on the tops of the 4x6 posts (pressure treated). This was the most difficult part of the job since two 2x12s had to be set on each pair of posts to form a 4x12 nail-lam beam. Having the 5525 with detachable bucket forks to lift these boards to nearly full height made this task pretty easy.
BTW: I celebrated my 67th birthday while doing this project which was my first attempt at a pole frame shed.
Material cost: about $3500.
I used a gravel floor for this shed. For my shop (24x42 ft metal frame building with 12ft walls) I had a contractor pour the slab. Leave that work to the pros. I also had the shop building installed by a contractor.
I plan to build two additional all metal sheds similar to the one noted above. These will be 18x27 ft structures with 9.5 ft wall height. I'll order the material and assemble them myself later this year. I expect this project to be a lot easier than the wood frame shed since the parts count is much lower for the all metal shed and the metal frame components are quite a bit lighter weight than the lumber I used for the wood frame shed.
NORSTAR SERVICE BED (A45046)
NORSTAR SERVICE...
Scag 36 Advantage (A44502)
Scag 36 Advantage...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A43004)
2016 FREIGHTLINER...
2000 LUFKIN TRAILER END DUMP (A45046)
2000 LUFKIN...
2011 Nissan Pathfinder AWD SUV (A44572)
2011 Nissan...
2013 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A45333)
2013 KENWORTH T800...
