Who writes owners manuals?
   / Who writes owners manuals? #31
Whoever wrote the manual for my GC1735 either knew it too well that they skipped a lot of steps that they did from memory, or they didn't know it at all and wrote it from looking at it without trying anything. The directions on installing / removing the mid mount mower were useless and skipped three steps, and there were no instructions on the rear hitch. I know 99% of you all know all about a 3pt, but not all of us have experience when buying a SCUT so a manual written for us and not the experts would be more helpful.
But was it ever any different? 50 years ago there were the "insert tab A into slot B" jokes about parents trying to assemble a bicycle or other gadget on Christmas eve and the frustration that involved.
Even relatively well-written technical manuals aren't very good unless you already know the equipment pretty well and are looking for detailed info on a particular sub-assembly.
He said write the instructions like you were describing how to de fuse a bomb....
Meaning don't say things like....
Cut the blue wire only after cutting the red wire...
Think about it...
OK, a bit OT, but that always bugged me about tv shows showing someone de-fusing a bomb. Do they really expect us to believe that every nutjob bomber uses the same standardized color code for wiring it (not to mention always including a digital timer)?
   / Who writes owners manuals? #32
Ten years ago, before I retired, I spent quite some time writing detailed instructions on how to download then update the navigation database on the corporate aircraft I was flying. This was to facilitate the ongoing updates every month for the times when I was on holidays, sick leave, etc.
I tested the accuracy and completeness of the instructions, making amendments where necessary, many times until I was satisfied they were accurate, logical, concise and foolproof.
Then I had one of my colleagues attempt the procedure, with me looking over his shoulder.
Well, I was staggered, disappointed, and totally P***ed off when he blew it - mis-read the instructions, got out of sync with them, left vital steps undone, and ended up totally lost. I concluded that either he didn't want to be lumbered with this responsibility in the event of my absence, or that he had an issue with following technical procedures.
So with lawyers writing the manuals for everything these days, and the tendency for folk to ignore them anyway, coupled with the trend towards dumbing-down the human population, I worry!
   / Who writes owners manuals? #33
I have written instructions for various procedures, usually involving computers. For my "testing" I would find someone who is not familiar with the task and have them try to follow the instructions. It was a good way to find errors or missing knowledge that I assumed everyone knew.
Doug in SW IA
I’ve done the same, and with lots of screen shots.
   / Who writes owners manuals? #34
There is that also.... Many people will read the instruction ...first, assemble tab A into slot B... But not believe it.. At least that is what I have to suspect...
Every time I got a new machine in the tool and die shop, I read the manual, made notes to myself as I went along the procedures.. Made notes from all that.. Made a procedure of how to do things with that machine.. I had more than one person in the shop I thought I taught to start, set up, run the machine.. But they turned out to need retrained each morning..
They didn't last long...
   / Who writes owners manuals? #35
Then you have people like me.
I look over the item that comes with a 10 page manual, lay out all the parts, toss the manual and assemble simply using logic, but then I am a very visual type.
Hey, a 1/2 " bolt simply won't fit 1 1/4" hole!
But then I can eyeball difference between 1/2" and 7/16" and usually spot a picture frame that is not level and plumb.
Logic also comes into play, hydro poles were always 'planted' plumb and water is always level.
Again yesterday. Bought a seed spreader and it was so simple to assemble and operate. Good thing because the manual was about average....that is, bad.
One example...they had a 4 step check list, A,B,C,D. They have excellent arrows pointing out A and B. When it came to C and D, they forgot the arrows.
They reference a brass control nut or something. Doesn't exist or, if it does, i can't find it.
It's so obvious that owners manuals, like customer service, is nothing more than a second thought, what my dad called lip service.
Like in the gadget industry, some 13 year old girl will eventually figure it out.
   / Who writes owners manuals? #37
Then there is the vicious and diabolical person in the factory that throws in an extra screw, spring, or bracket in the box. :unsure:
   / Who writes owners manuals? #38
Anybody else running my equipment stopped when I observed my neighbor's hired help keeping my tractor at max rpm idling in place. They were working a drainage project and couldn't be bothered to idle down when they got off the tractor for a few minutes.
I run at about 80% max, moving up when I need the additional power. I don't need to burn the fuel or shorten the engine and pumps' lives at higher RPM than is necessary to do the job. I turn the idle down when doing low or medium speed tasks.
I've asked the Engineers (Design & Service), the dealers, the dealer techs and local operators. None can provide a valid technical reason to max out the RPMs all the time, but most operators max out the throttle right after warm up......because it's not their machine. They are not concerned with the service life or cost. Their focus is work completion rapidly....check out the rear of every jobsite SSL, MTL/CTL and excavator for the results of this focus.
That tells me that the engineers aren't doing much testing.... (which isn't much of a surprise - and some times it's intentional if the design and testing responsibilities are divided in the organization for design quality/verification reasons).
Have been party to the testing of multiple engines (to include some diesel engines) for aviation applications, I've seen that frequently the real killer of engines is rapid/frequent throttle changes (i.e. not letting the engine run at a consistent throttle setting). An engine left to sit running at a consistent throttle setting close to a design point (usually above idle) tends to last far longer than one where the throttle is being banged around extraneously (which I'd wager most tractor owners don't do) -- and if the throttle is being jerked around at rates faster than the engine (or it's turbocharger) can even respond to the changes it can destroy an engine in very short order. Saw that last situation play out as a result of software engineers being in charge of controlling the engine throttle as part of controlling the vehicle as a whole ---- despite they're having zero experience with turbo-charged diesel engines.
Of course, that's just for the engine ...other parts of the system can be affected differently. So at an assembled system level it really depends on how all the parts were designed, assembled and work together (or against each other) as to whether mechanical wear or purely mechanical fatigue or thermal fatigue is the more damaging problem.
Which brings up the reality that most of the time when engineers are designing something they're are designing/optimizing for a few pre-selected operating points, rather than ensuring operating characteristics for the entire operating range (which is how situations like oil pumps potentially not pumping sufficient oil for the engine at idle speeds arise).
The other part of that is the engineers working one part of a complex system generally don't interact with the engineers designing other parts of the system (even if they work for the same company) unless they have specific requirements to do so (e.g. transmission interfacing to an engine). Of course that's in a well run organization, in a poorly run organization the engineers working different parts of a system may start making assumptions about (or just ignore) what the engineers working connected pieces are doing to design their respective parts of the system.
All that being said engineers working on a project are generally the last people anyone should want writing an operator's manual ...and that's speaking as an engineer.
If a company wants to have a good manual, at a minimum it will likely be written by a technical writer with some input information from all the various engineering groups (mostly to capture operating limits, technical specifications like fastener torques, and maintenance intervals), as well as have a user & maintainer validation process to make sure that the manual as written actually makes sense from a user & maintainer perspective. .....all of which isn't cheap to do.
So if/when the end user isn't likely to read the manual -- or have the quality of support (to include quality of manuals) play a part in purchasing decisions......
   / Who writes owners manuals? #39
The same people that six months later go to work at a nuclear power plant writing work procedures. Tech manuals used to be written as the mechanic was performing the work. I'm sure that's not the case any longer.
No one gets to write power plant instructions, unless they know the equipment and how it is connected to other equipment and the plant operations. -- Did that work for 30 years.
   / Who writes owners manuals? #40
My last couple companies used the sales department to write up manuals.
The salesman would make daily visits to engineering personnel for details they weren’t familiar with.
The companies saw it as a win/win because it forced the salesmen to become deeply familiar with the product they were selling
Booster Cables (A59230)
Booster Cables...
Electric Golf Cart (A57149)
Electric Golf Cart...
UNUSED JCT 84" HYD ANGLE BLADE (A58376)
UNUSED JCT 84" HYD...
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A57453)
2000 Volvo VNL...
2004 Timber King TK350 Wheeled Feller Buncher (A59213)
2004 Timber King...
2016 Ford F-350XL (A57148)
2016 Ford F-350XL...
