Who still drives a stick in 2025?
   / Who still drives a stick in 2025? #401
Found an abandoned Russian car of some sort and swiped the shift knob from it. It had a basic 4-speed pattern, except upside down.
That became interesting when taking my Autobianchi (basically a Fiat 500) in for its annual inspection. Keep in mind that it was an 18.5 hp car with a non-synchro First.
Predictably, the testing guy put it in Second to take off, stalled it a couple of times, but eventually managed to get it rolling - only to then try putting it in what he thought was Second.
After a few loud attempts he figured he'd skip "Second" and go to what he thought was Third. Not only was Fourth an overdrive gear, but by now we'd lost enough speed that there was no way it'd run in "Third".
I became a rather short and slow test drive as he settled for driving back in the only gear he'd had some success with...what he thought was First. It was very hard to keep a straight face, and the car passed inspection. Not so much because everything was good on it, but the guy was quite embarrassed.
   / Who still drives a stick in 2025? #402
That would be a way to slow down a car thief, out a knob of a different gear pattern on the stick. Not that many thieves know how to drive sticks.
   / Who still drives a stick in 2025? #403
I seem to remember an episode of Top Gear with a special model of Mercedes that had a backward shift pattern. Hilarity ensued.
   / Who still drives a stick in 2025? #404
Is taking a test drive part of the inspection process where you live? Never heard of that. Here it's pretty much put it on the lift, check for exhaust leaks, rust holes in the floor, make sure brake pads/shoes have sufficient lining, test lights & wipers and done.
   / Who still drives a stick in 2025? #405
No inspections of any kind here, but where I grew up in Europe there was.
Finding an abandoned Russian car on the side of the road should've been the strongest hint to that it didn't happen in the USA.
   / Who still drives a stick in 2025? #406
I have a Chinese B2 driver's license, which means I can drive most cars except for towing trucks, but unfortunately I have only driven a heavy dump truck once since I graduated from driving school
   / Who still drives a stick in 2025? #407
That truck was my uncle's, the Red Rock Jieshi, 520 horsepower, 16-speed manual transmission
   / Who still drives a stick in 2025? #409
Here in rural PA, the annual $50 tax to obtain a 25¢ inspection decal includes a test drive...
If you have a fast car with a trip computer, it's always entertaining to see what the tech does with it on that test drive. One year, I found teh inspection tech got the car up to 93 mph without ever traveling more than 0.4 miles from the dealership.
I'd actually not mind it if the dealership were located near a limited-access expressway. It's a 200 mph car so it's just barely stretching its legs at 93 mph. But there is no road clear of constant traffic within 0.4 miles of this dealership with any speed limit above 35 mph, and it's mostly residential, so the chances of having neighbors call in your plate to complain to the police is a real concern. I don't need the police stopping by my house to inquire about a complaint that my vehicle was seen blasting thru a residential area at 90+ mph last Tuesday morning.
   / Who still drives a stick in 2025? #410
The crap weather is actually doing me a favor.
I won't bring Petunia out until the roads are dry and free of winter grit+++.
It's hard not to go for a drive when it's warm and dry.
Very little of that this year. Spring has been more a date on the calendar than in practice.
2017 International WorkStar 7500 Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A56858)
2017 International...
JOHN DEERE 6500 HI-CYCLE SPRAYER (A52708)
JOHN DEERE 6500...
DMD 3PT DISC MOWER (A52708)
DMD 3PT DISC MOWER...
Heavy Duty Solid Steel Skid Steer Mounting Plate (New/Unused) (A59225)
Heavy Duty Solid...
2017 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
(2) 42" HANG ON FORKS (A54757)
(2) 42" HANG ON...
