Who rides motorcycles?
   / Who rides motorcycles? #2,571
I installed that meter/usb port thingy on the handlebars. It has an on/off switch which makes it easy to check the battery charge when it's sitting now as it has for a week while I make some changes. I changed the front sprocket 15T to 14T yesterday and finish the skid plate installation. Unfortunately the EVAP canister and bracket had to be removed to make the skid plate fit. So now I'm modifying the bracket and moving it's location higher up on the frame but, the welder is acting up and needs some attention now...new stinger arrived.
I got the saddlebag supports installed and rear rack remounted. What a CF that was with 2 different Chinese mods trying to mount on the same brackets. 😖 But it feels solid and will keep the bags off the pipe on 1 side and out of the pokes on the other.
Bought some new tires and cheap changer /balancer set up. The fun continues, I do enjoy improving things.
   / Who rides motorcycles? #2,572
I see a couple of persuaders on the floor there.
   / Who rides motorcycles? #2,573
Good eye. I had to remove a canister bracket for the EVAP system. Mostly with the grinder but the access angle was poor. The big hammer and chisel finished that and removed a fuel line support loop. All so I can raise the EVAP can up (above the skid plate) and reinstall... California only bikes have that EVAP can I think :rolleyes: Case you didn't know it's a charcoal canister that collects gas fumes and sends them to the combustion chamber (I didn't know until I had to deal with it)
Anyway I got the title transferred today at my little AAA office. Quick and easy compared to our nightmarish DMV. So she's mine in the eyes of the state... Bought insurance with my reular State Farm agent. It cost a little more than Gieco but coverage was double with uninsured driver.
Being there are 10 mil illegals driving around that seemed like a good idea.
Time for supper. Have a good night.
   / Who rides motorcycles? #2,574
One or the shortest connection hoses to the fuel evap system on my "new" Vespa GTS250 was broken (due to age) when I got the bike home. Who knows how long it had been so.
It's in such a PIA location, I just pulled another hose off the fuel injection manifold and capped the port.
I hope no one notices.....
The bike runs just fine without it! ;-)
I had to run into town after supper this evening. I took the Honda VFR800. Dang I like that bike. It does everything so well.
The night air was cool for a change....Nice.
   / Who rides motorcycles? #2,576
I'm posting a tire changer review here cuz I told somebody in what did you buy I would...
All Amazon cheap products aka not the best but it'll do quality.
Tire changer $44 > Amazon.com: TUFFIOM 16-21 Inch Tire Changing Stand, Off-Road VehicleMotorcycleDirt Bike Stand Tire Changing Bead Remover, Tire Changing Repair Kit : Automotive
Tire balancer $51 > Amazon.com: Orion Motor Tech Motorcycle Bike Wheel Balancer, Tire Balancer Stand with Adjustable Centering Cones, Heavy Duty Motorcycle Wheel Balancing Stand, Portable Bicycle Wheel Balancer for up to 12" Tires : Automotive
Tire spoons $10 > amazon.com/dp/B0D4KFCFVY?ref=fed_asin_title
Wheel weights $20 > Amazon.com: DEWHEL 14 Pack Brass Motorcycle Reusable Wheel Spoke Balance Weights Refill Kits Compatible with Super Moto,Dual sport,metric cruisers,vintage,or any other spoked wheels : Automotive
Install assist tool $10 >https://www.amazon.com/dp/B0CW1ZYFR9?ref=fed_asin_title&th=1
$135 total >For the prive of what they charge locally I'm in the tire change business.
Quality on all items was acceptable. I had only one issue with the changer. See in the pics it has a center axle the hub slides onto and a big wing nut threads on the hold the wheel. Well the rod was the same 15mm size as my hubs but somehow they made threads on the end that actually increased the outside dimension on the threaded section. And it was a no go until I sanded off the excess which removed about half the thread but it still works. 3 stars, other wise it works okay, the bead breaker is fine and it was surprisingly stable on a table top. Good for $44 once you remedy the thread debacle.
The balancer works a charm. Maybe $10 overpriced but hey, free shipping on everything.
The cheap spoons worked great. Good tube safe finish. And perfect size. I also have a pr of HF spoons and they are kinda big for MC tires but I did need a 3rd spoon once and it came in handy... also if HF spoons are all you have they can work. It's all I had for the rear tire and I made it work.
The little red bead stop acts like a permanent spoon when installing to hold your starting point down. $10 for a 3rd hand you can use over and over.
I'm happy with it all and looking forward to many more changes.
By the way, I went with a D606 rear and MT-21 front
   / Who rides motorcycles? #2,577
I have a similar balancer that I got 15-20 years ago, only used it a half dozen times. But it sure was handy to have.
   / Who rides motorcycles? #2,578
I approve of anyone changing their own tires.
The caveat with that balancer is the 4 bearings must be parallel and square to the shaft. My first cost twice as much from the NoMar people and was junk. Surrendered and purchased a Marc Parnes balancer and have nothing but smiles. The Marc Parnes is so sensive it will try to balance the wing nuts on its cones with no wheel mounted. Uses a single bearing on the 1/2” shaft at each end.
During the peak 5 years of my riding I mounted about 60 tubeless motorcycle tires for myself and friends I rode with. 24 of my own tires.
Used a Cycle Hill changing stand from NoMar.
   / Who rides motorcycles? #2,580
It's not for everyone, but for M/C wheel balancing, I use an "adapted" lawn mower blade balancer
I don't use the supplied base, but rather a longer pointed metal rod made from a punch.
I have had to spin up a variety of special adaptors to fit the various bikes I've had over the years.
I just plumb the pin vertical in the bench vise. Place the wheel /tire assembly on the cone (with custom adaptors as required) set up some sort of reference at the wheel rim, and then slowly spin the wheel.
The high spot is light! So on goes one of those sticky weights!
I've done both VFR (Sport bike) and Scooter tires this year.
I KNOW the sport bike jobe is good for over 100mph. ;-) And the scooter is smooth as silk up to 70mph.
An option for any who might want to try.
Fortunately, I have several lathes to spin up any adaptors needed.
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
2017 Kia Sedona LX Van (A51694)
2017 Kia Sedona LX...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
