Backhoe Who makes the Kubota BL4690 Backhoe?
   / Who makes the Kubota BL4690 Backhoe? #1
PBinWA
Platinum Member
WA
Kioti NX55, Mahindra 2615, Case 36CXB, Case W4, Volvo MC85C
Does anyone know if the Kubota BL4690 Backhoe is made by Kubota or is it re-badged from a US vendor?
I'm looking at a used one and want to see if I can get a sub-frame for my non-Kubota Tractor.
Thanks,
PB
   / Who makes the Kubota BL4690 Backhoe? #2
I believe it is made by Kubota in their Georgia factory.
Thanks Mad! If I go for it, I think I'll have a welding project in the sub-frame.
   / Who makes the Kubota BL4690 Backhoe? #4
Thanks,
PB
PB,
Why not get a sub-frame and brackets from your tractor manufacture, then modify it to work with the Kubota hoe. That way, you won't have anywhere near as much fabricating to do.
   / Who makes the Kubota BL4690 Backhoe? #5
The BL4690 is a 3point hitch mounted BH. Even if you knew who made it, they wouldnt have a subframe for it and you would still have to fabricate something.
   / Who makes the Kubota BL4690 Backhoe? #6
If he did it the way I was suggesting, all he would have to modify would be where the Mahindra Sub-frame met up with the frame of the Kubota backhoe.
   / Who makes the Kubota BL4690 Backhoe? #7
Agreed. I was just sorta expanding on what you said. That would be the only way I see it working since the BH doesnt really have a subframe available.
   / Who makes the Kubota BL4690 Backhoe? #8
That's all right, my post wasn't very concise.
I really wish that when we post that it would show which post we were referring to like the old software did.
Feteral 8"x60' Transport Auger (A50774)
Feteral 8"x60'...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-250...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2014 Bobcat 15C Skidloader PHD (A50774)
2014 Bobcat 15C...
2011 PJ Tilt Deck Gooseneck Trailer (A50514)
2011 PJ Tilt Deck...
(6) MF Suitcase Weights (A50515)
(6) MF Suitcase...
