Who makes the best snow tracks?
   / Who makes the best snow tracks? #1
XM16E1
None Yet
Have a new Bobcat T770 and would like to use it for snow removal. Need to keep clear approximately three acres of space. Ground is mostly level with a gravel surface. In Alaska so we get a lot of snow and very cold winters.
What are the best set of snow tracks I can order for my machine? Studs are out since I dont want them chewing up my concete surfaces. Hoping to find a set in stock or at least one that can be shipped within a couple of weeks.
Thanks for the advice and recommendations!
   / Who makes the best snow tracks? #2
Can’t help you on a recommendation for tracks, but you may want to also try posting in the TBN Bobcat and Skidsteer forums if you have not already so. Good luck.
   / Who makes the best snow tracks? #3
Alaska is correct, you'd have better luck asking this in the Bobcat section or in the snow removal one. We get real snow here and no one uses those carbide tipped studs. Good luck.
   / Who makes the best snow tracks? #4
Contact GCR tires and service in Anchorage AK for Firestone/Bridgestone Polar tread rubber tracks
   / Who makes the best snow tracks? #6
Clean "new" nearly wet ice, in the last few seconds the track of the opposing bobcat was running backwards.
Dealing with slippage, needing adhesion at all times, and needing floatation all times are the things that go hand
in hand for any skid steer.
If either machine had carbide teeth in the rubber tracks.......
   / Who makes the best snow tracks? #7
How is the search going? FYI, there is a vendor advertising replacement tracks for skidsteers and excavators in the equipment section of the Fairbank痴 Craigslist.
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
2832 (A58376)
2832 (A58376)
EZ loader trailer (A56857)
EZ loader trailer...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
LOT: Fill-Rite Pump, Fuel Transfer Tank, Tool Box (A59076)
LOT: Fill-Rite...
