Posthole Digger Who makes the best PTO 3 pt Post hole digger?
   / Who makes the best PTO 3 pt Post hole digger? #1
Ob1kubota
I'm looking for members who have experience with post hole diggers in the 60 to 90 horse power range at PTO, thanks! Old Ob1
   / Who makes the best PTO 3 pt Post hole digger? #3
No experience. . . .yet. Been looking at the Landpride PD35.
   / Who makes the best PTO 3 pt Post hole digger? #5
I know Danuser has a good name with the hydraulic heads.
May I ask what you are going to be doing ?
jb
   / Who makes the best PTO 3 pt Post hole digger? #6
I had a Danuser F8 and it gets my endorsement but as good as it was you couldn't run me down to give me one. If you've ever used a hole digger mounted to a skid steer its over for anything else.
Footer construction for prefab steel buildings. heavy steel post for fence & gates that will stop an 18 wheeler and with a proper sized auger 4x4 & 6x6 treated fence post for cattle and horses. Thanks Ob1
Krumps ...... Wow! that thing has a mast like my Altec Pressure Diggers. Definitly saved it to favorites! Thanks Old Ob1
   / Who makes the best PTO 3 pt Post hole digger? #9
Land Pride PD35 for me, rated for 75 pto horse power. 6,9,12,15,18,& 24" augers available, all dig 48" deep. 6,9,& 12" augers are semi- double flighted with the remaining sizes being double flighted. All augers have replaceable hardened cast steel teeth. 7 & 14" auger extensions available. Hydraulic down pressure kit available that applies 500lbs of down force if needed.
This is the unit that I have and it is a very heavy duty unit.:) Among the best PTO units available.
Good luck with your search.
   / Who makes the best PTO 3 pt Post hole digger? #10
Bent the he** out of mine.:mad: Maybe I had a some sort of factory defect that was undetected..it only dug 30 or so holes before it bent. Had to heat it up and use the tractor to straighten it back out... After 3 hours of heating and torquing, and welding some 3/8" reinforcements, it worked OK again. I have a couple of Landpride implements...average at best.
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
2017 Volkswagen Jetta Sedan (A50324)
2017 Volkswagen...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646718 (A51572)
2013 Dodge Charger...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52748)
2023 New Holland...
2015 Ford Expedition EL XLT SUV (A50324)
2015 Ford...
Case SV 340 Skid Steer Loader (A52349)
Case SV 340 Skid...
