Who Makes Smaller Snow Buckets?
   / Who Makes Smaller Snow Buckets? #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
Looking for a 60" or maybe 66" snow bucket for an LS XJ2025 with SSQA connection.
Some of those heavy duty buckets for skid steers may weigh upwards of 700# which is too heavy for me.
The smallest bucket I found so far is 72" which might possibly work - but still on the bigger side.
Any help is appreciated.
TIA
Yooper Dave
   / Who Makes Smaller Snow Buckets? #2
Are you looking to go smaller in size or lighter ? Or both.?
I personally would go as big as I could but " light"..
I just bought a new LS XJ2025. I found out that it is illegal to push snow across the road so a pusher will not work. Therefore I can use a snow bucket and place the snow anywhere I want.
I will have rim guard in the tires, and with me on the seat will add 1,000# of ballast.
I did not want too wide of a bucket, as it will take more traction to facilitate. The tractor is 50" wide.
I found a 60" bucket and it weighs 500#. That leaves quite a bit of weight left to pick up snow.
The driveway is paved ~ 50' x 130' with a slope.
Regards,
Yooper Dave
   / Who Makes Smaller Snow Buckets? #4
Worksaver makes some nice snow pushers of all different sizes from 52" on up. Can you not push the snow with a pusher to the area you would build a pile?
A cheaper method would be to use the Edge Tamer skids for use on your existing bucket. Or you could always buy a rear blade and turn it around backwards so it doesn't cut-it when pulling snow, or keep it facing forward and push it in reverse. I've never seen skids like the ones Edge Tamer builds, however, I think for what they are their price is a little expensive. I am sure I can build them my self or have them built for less than their cost on a set.
https://www.worksaver.com/snow-pushers
R2 Manufacturing - Home Of The Edge Tamer
2015 CATERPILLAR 336FL EXCAVATOR (A51242)
2015 CATERPILLAR...
2018 John Deere 333G (A47384)
2018 John Deere...
71050 (A49346)
71050 (A49346)
2022 John Deere S780 Combine (A50657)
2022 John Deere...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
