Spreader Who makes a H.D. poly PTO spreader w/ S.S. gears?
   / Who makes a H.D. poly PTO spreader w/ S.S. gears?
I GAVE UP.
I just purchased a small (100# hopper) 12-volt salt spreader that I will front mount for the winter. It uses an aluminum hopper and stainless spreader parts. Mounts on a 2" receiver hitch for use on a truck, I intend to front mount it (somehow). That way I can use the blower on the rear and spread salt off the front of the tractor. I may mount it to the front bumper with the FEL removed? Or maybe clamp it to the top of the bucket so the FEL can stay on? Leaning toward removing the FEL (I usually leave it off in the winter). Got it on Ebay for $269. Not great, but it will do for salt spreading around the drive and entry areas.
I will then continue my search for my ideal (or the next best thing) 3pt spreader for seed/fertilizer with approximately a 250# capacity.
-- I like the unit from Thompson Seeders, but the capacity is 200#, it uses a galvenized hopper.
-- I also like the HERD Seeders, but near as I can tell they discontinued the model that I liked.
-- Befco Hop is high on my list, if for no other reason than they make top quality stuff so I presume their spreader is also top notch.
But from what I can see, all of the small PTO driven spreaders (under 500+# capacity) use hoppers are made of painted steel. Big stuff for real farmers has fiberglass or poly hoppers.
   / Who makes a H.D. poly PTO spreader w/ S.S. gears? #22
Just a side comment, Bob. You can probably trash out 5 or 7 cheaper spreaders for less than the price of one stainless spreader that will certainly break down somehow, sometime, even if not from corrosion. I seek out the quality stuff, too, but sometimes the business math and long term costs don't make sense. Just another $0.02. If everybody keeps throwing in their $ 0.02, you'll have enough to have one custom made /forums/images/graemlins/grin.gif
2008 Ford F-450 14FT Flatbed Truck (A51692)
2008 Ford F-450...
PIONEER PUMP 4 TRANSFER PUMP (A55745)
PIONEER PUMP 4...
2013 Dodge Charger Sedan (A55853)
2013 Dodge Charger...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A55314)
2023 Kubota U48-5...
MINI SKID SDLL50 (A55745)
MINI SKID SDLL50...
