who likes/loves plowing with trucks? ?
   / who likes/loves plowing with trucks? ? #1
farm boy00
Howard City, MI
John Deere M&MT, Case 1030 comfort king, Sears ST16, Craftsmen 6000, homemade articulation mini-loader
Kinda curious on this. Have seen most people recommend using tractors or only run tractors. I understand that not everyone has plow trucks. I personally like plowing with trucks. I actually got 1 plowing job and am a back up plowers for a busdy when he goes out of the country for Christmas and I can't even fully drive yet.
So who likes there trucks??
Plow is still involved storage
   / who likes/loves plowing with trucks? ? #2
I had Ford 550 diesel dually with 14ft dump stake body and full behind the cab tool box setup with a 9 FT stainless Boss V plow to plow with once while working for a landscape business
Twas a beast to back up with :D
More than one driver took out a parking light pole with it
One guy backed over a car that came up too close behind him and into into his blind spot :eek:
For a while I was the only one the boss would let drive it :rolleyes:
You got to love those ford. Always a beast. 7.3 or 6.0
   / who likes/loves plowing with trucks? ? #4
My 83 Chevy, chained on all for corners, moves snow much faster than my 4x4 Yanmar 276D, chained in the rear. No comparison.
   / who likes/loves plowing with trucks? ? #5
Truck will be faster, issue you run into is stacking or putting it some where.
   / who likes/loves plowing with trucks? ? #6
Rear blade for my tractor was far less expensive than a blade for my truck so that's what I use. I suspect I'd enjoy it more in the truck though (heat, radio etc.).
I personally have never had stacking problems through these hard Michigan withers last few years while plowing. One lot I has the corner pile 10'+ tall stacking it. Although my truck (duramax) does give good torque if not spinning
   / who likes/loves plowing with trucks? ? #8
I had a real nice plow (RT3 Boss) and I like my snowblower/tractor better.
Takes me 1/2 the time.
My banks would get higher than the plow, and I'd just go over and over and over and over the same spot. Snow would always fall out of one side. Also it would go up the bank, then collapse back down. VERY frustrating.
Driveway is like 800' long. Several places to angle off and put snow, but other areas it isn't possible.
I drive out my driveway and back in at about 3mph+ Then some cleanup by the garage and turnaround area. DONE.
   / who likes/loves plowing with trucks? ? #9
I used to put a snowmobile suit on, sit on a hot seat, fight with the tractor (Farmall H) cranking over in sub zero, taking an hour or so plus to plow all the while sniffing fumes from the exhaust.......
Now I attach my plow to the truck in my attached garage, takes about two minutes. Plow sitting inside a heated cab wearing a tee shirt and sipping coffee and working my Western three way plow control. Takes about twenty to thirty minutes depending on the amount of snow. I'm not looking back!
   / who likes/loves plowing with trucks? ? #10
Plowing with pickups is fun, but plowing with a dump truck one way and a wing is funner. You don't need to worry about where to put the snow, when it comes off the one way at 30mph it really flies.
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53472)
LIKE NEW 2023...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
