Who knows this special grass growing formula
   / Who knows this special grass growing formula #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
A friend just told me about a mixture of Soda/Beer/Detergent/? that you spray on the yard that works miracles in getting grass to grow.
The soda does something
The beer adds microbes
The detergent helps the ground absorb the other stuff
Does anyone heard of this formula or what the exact formula is?
Brian
   / Who knows this special grass growing formula #2
I've never heard of it but I know the grass sure grows good in the spots where I washed my tractor. I was using liquid laundry detergent in the pressure washer because it takes grease off so well.
If there were a cheaper alternative to the 2 tons of fertilizer I buy every 28 days in the growing season I'd sure go for it. Beer, I think, Would be more expensive.
   / Who knows this special grass growing formula #3
I like having the excuse though.... Honey, I need this much beer for the grass :)
   / Who knows this special grass growing formula #4
I bet Milwaukee's Beast would be competitve in price.
Chuck
The guy (he is a straight shooter) said he heard it on a saturday morning radio talk show about gardening.. Someone tried it on spots in his yard that he had been working on for years to no avail.. This conconction worked and he was mowing the yard quite often afterward..
thanks
Brian
here is something i found saying it wont work..
May 19, 2005
Detergent, Soft Drinks and Beer Not Good
There's a reason spillage and dumping on the lawn isn't good. Walter Reeves tells us why.
"BEER FOR YOUR BERMUDA? I have mentioned before my disdain for television hucksters touting lawn care "formulas" made from household products. The presentation is enthusiastic but the recommendations contain only tiny nuggets of scientific truth.
It is true that household ammonia contains a small amount of the nitrogen fertilizer that turfgrass needs - but it evaporates before becoming available to the plants it is sprayed onto. It is verifiably true that detergents can make other chemicals spread and stick to the leaves of plants - but the proportion of detergent should be only a few drops (not tablespoons) per gallon. Otherwise, the detergent will burn the plant leaves like a herbicide would. It is true that soil micro-organisms need and consume carbohydrates - but they specialize in the complex carbohydrates found in plants, not the simple sugars found in soft drinks and beer.
Sometimes I just want to slap the folks promoting horticulture pseudo-science.
SNAKE OIL In the nineteenth century, many a good living was made by hawking snake oil liniment. It was “Good for What Ails You!” and was accompanied by fevered pitches featuring “scientific” research and experts. Snakes do not produce oil and the “experts” were bogus. Those facts, though, didn’t prevent gullible people from stuffing wads of dollars under the suspenders of snake oil salesmen.
When you hear “scientific” claims for garden processes or products, use the little bit of science you still remember to evaluate the assertions. You may discover, like me, that you have no aptitude for science but I’ll bet you have enough common sense to eliminate the hogwash."
website - look for the May 19 2005 postings
Lawn Care - Lawns : The Green View
any comments..
Brian
   / Who knows this special grass growing formula #8
Laundry detergent used to be really good until they went earth friendly and removed most if not all the phosphorus, which of course is the "P" in NPK.
   / Who knows this special grass growing formula #9
I have used a similar formula.
It was amonia, beer and soda and dish soap. Not worthwhile to put on your lawn, IMO. To much labour and expense. I didn't see any tangible results.
In case you are wondering watering your lawn with beer does not make it grow half cut. :rolleyes:
But, amonia, dish soap and water is great to kill bugs on plants and degrease an engine. I used to keep a squirt bottled mixed in the garage.
   / Who knows this special grass growing formula #10
I don't know about the soda, beer, detergent mix. I needed the opposite. I wanted to have a place to park my 30' camper and didn't want grass to grow under it. My local highway department was scraping up roadside dirt one spring and I asked about using that dirt as a base fill to use under my camper. The guys told me they would give my as much as I want but not to expect grass to grow since it was contaminated with all the road salt from winter plowing. I said that was exactly what I wanted. I had them dump 2 ten wheeler loads, I leveled it out and parked my camper there. By the end on summer I had to mow it each time I did my lawn. So much for that theory.
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
10'x6' Sea Container W/ Side Door (A47477)
10'x6' Sea...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
(INOP) 2016 FORD F150 XL SINGLE CAB TRUCK (A51406)
(INOP) 2016 FORD...
2025 JMR 40in Single Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 40in...
